I have discovered a new serious issue that was not happening prior to upgrading to firmware 2.0.   This issue is with focus peaking and capture assistants.  I have various capturing assistants customized for the four “Info Profiles”.   I have “focus peaking” turned on all of the profiles along with others dependent on each profile.  For example, I have “leaves gauge” and “grid” plus “focus peaking” on Info Profile 1.  I then have the FN button on back of camera programmed to “Toggle Info Levels”  so that I can easily cycle through the various “Info Profiles” with the different settings.  No matter what I do I cannot get the focus peaking to enable as I cycle through the “info Profiles”.  This is serious issue, as focus peaking is a key function used with M lenses and primary benefit of using the SL camera to help easily capture sharp focus.  Anyone else have this same issue or have a recommended resolution.  I have tried reprogramming all the customized “info profiles” and still will not work.
10 hours ago, AZach said:
Yes, this is explained p.16 of the release notes that are included in the installation instructions file of version 2.0.
https://en.leica-camera.com/Photography/Leica-SL/Leica-SL2/Firmware
Thank you.  Unfortunately, I get an error every time I have tried to download the release notes that the webpage is unavailable, so have not been able to access them.  Just tried again and finally working.
  • 2 weeks later...
6 hours ago, Nick Guttridge said:
With focus assist, can you have peaking when you are automatically zoomed in. I don't seem to have that. I only have peaking in the whole frame.
Check your settings. It's functioning fine on my SL2-S.
