42 minutes ago, stallus said:
What shows exiftool with your DNG files?
<snip
No issues on mine (see exif dump below). Do you look at the file on SD card or after the import?
ExifTool Version Number         : 12.30
File Name                       : L1000108.DNG
Directory                       : /Volumes/LEICA SL2S/DCIM/100LEICA
File Size                       : 43 MiB
File Modification Date/Time     : 2021:09:23 15:09:49-07:00
File Access Date/Time           : 2021:09:23 15:11:24-07:00
File Inode Change Date/Time     : 2021:09:23 15:09:49-07:00
File Permissions                : -rwxrwxrwx
File Type                       : DNG
File Type Extension             : dng
MIME Type                       : image/x-adobe-dng
Exif Byte Order                 : Little-endian (Intel, II)
Make                            : LEICA CAMERA AG
Camera Model Name               : LEICA SL2-S
Orientation                     : Horizontal (normal)
Software                        : 2.12
Modify Date                     : 2021:09:23 15:09:49
Artist                          :
Image Width                     : 6048
Image Height                    : 4048
Bits Per Sample                 : 14
Compression                     : Uncompressed
Photometric Interpretation      : Color Filter Array
Strip Offsets                   : 1881088
Samples Per Pixel               : 1
Rows Per Strip                  : 4048
Strip Byte Counts               : 42844160
X Resolution                    : 300
Y Resolution                    : 300
Resolution Unit                 : inches
CFA Repeat Pattern Dim          : 2 2
CFA Pattern 2                   : 0 1 1 2
CFA Layout                      : Rectangular
Black Level Repeat Dim          : 2 2
Black Level                     : 510 510 510 510
White Level                     : 16383
Default Crop Origin             : 12 24
Default Crop Size               : 6000 4000
Bayer Green Split               : 0
Anti Alias Strength             : 0.7
Best Quality Scale              : 1
Raw Data Unique ID              : 6C0031090F1709E5077AE15500000000
Active Area                     : 0 0 4048 6024
Opcode List 1                   : FixBadPixelsConstant
Opcode List 3                   : WarpRectilinear
Default User Crop               : 0 0 1 1
Preview Image Start             : 1715712
Preview Image Length            : 165376
Subfile Type                    : Reduced-resolution image
Jpg From Raw Start              : 120320
Jpg From Raw Length             : 1595392
About                           : Leica Camera AG
Rating                          : 0
Copyright                       :
Exposure Time                   : 1/15
F Number                        : 4.5
Exposure Program                : Aperture-priority AE
ISO                             : 320
Sensitivity Type                : Standard Output Sensitivity
Standard Output Sensitivity     : 320
Exif Version                    : 0231
Date/Time Original              : 2021:09:23 15:09:49
Create Date                     : 2021:09:23 15:09:49
Offset Time                     : +02:00
Offset Time Original            : +02:00
Offset Time Digitized           : +02:00
Components Configuration        : Y, Cb, Cr, -
Exposure Compensation           : 0
Max Aperture Value              : 3.6
Metering Mode                   : Multi-segment
Light Source                    : Unknown
Flash                           : Off, Did not fire
Focal Length                    : 24.0 mm
Serial Number                   : 5628282
Original File Name              : L1000108.DNG
Original Directory              : 100LEICA
Focus Distance                  : 10.952 m
File Index                      : 108
Film Mode                       :
WB RGB Levels                   : 0.4625112918 1 0.5145728643
Internal Serial Number          : (XEL) 2020:11:19 no. 0041
Flashpix Version                : 0100
Color Space                     : sRGB
Exif Image Width                : 6048
Exif Image Height               : 4048
Sensing Method                  : One-chip color area
File Source                     : Digital Camera
Custom Rendered                 : Normal
White Balance                   : Auto
Digital Zoom Ratio              : undef
Focal Length In 35mm Format     : 24 mm
Scene Capture Type              : Standard
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Lens Info                       : 24mm f/3.66796875
Lens Make                       : SIGMA
Lens Model                      : 24mm F3.5 DG DN | Contemporary 021
Lens Serial Number              : 5532243
DNG Version                     : 1.4.0.0
DNG Backward Version            : 1.3.0.0
Unique Camera Model             : LEICA SL2-S
Localized Camera Model          : LEICA SL2-S
Color Matrix 1                  : 1.0946 -0.4156 0.0254 -0.487 1.4366 0.3355 -0.0791 0.1776 0.7477
Color Matrix 2                  : 0.7275 -0.198 -0.0514 -0.4369 1.1949 0.2302 -0.127 0.2137 0.5473
As Shot Neutral                 : 0.4625112918 1 0.5145728643
Baseline Exposure               : 0
Baseline Noise                  : 1
Baseline Sharpness              : 1
Linear Response Limit           : 1
Camera Serial Number            : 5628282
Maker Note Safety               : Unsafe
Calibration Illuminant 1        : Standard Light A
Calibration Illuminant 2        : D50
Aperture                        : 4.5
Blue Balance                    : 0.514573
CFA Pattern                     : [Red,Green][Green,Blue]
Image Size                      : 6048x4048
Jpg From Raw                    : (Binary data 1595392 bytes, use -b option to extract)
Megapixels                      : 24.5
Preview Image                   : (Binary data 165376 bytes, use -b option to extract)
Red Balance                     : 0.462511
Scale Factor To 35 mm Equivalent: 1.0
Shutter Speed                   : 1/15
Create Date                     : 2021:09:23 15:09:49+02:00
Date/Time Original              : 2021:09:23 15:09:49+02:00
Modify Date                     : 2021:09:23 15:09:49+02:00
Circle Of Confusion             : 0.030 mm
Depth Of Field                  : inf (3.07 m - inf)
Field Of View                   : 73.6 deg (16.39 m)
Focal Length                    : 24.0 mm (35 mm equivalent: 24.0 mm)
Hyperfocal Distance             : 4.26 m
Light Value                     : 6.6
Lens ID                         : 24mm F3.5 DG DN | Contemporary 021
vor 7 Stunden schrieb SrMi:
File Size                       : 43 MiB
File Type                       : DNG
Software                        : 2.12
Artist                          :
Image Width                     : 6048
Image Height                    : 4048
X Resolution                    : 300
Y Resolution                    : 300
White Level                     : 16383
Rating                          : 0
Copyright                       :
F Number                        : 4.5
ISO                             : 320
Exif Version                    : 0231
File Index                      : 108
Film Mode                       :
Color Space                     : sRGB
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Lens Make                       : SIGMA
Baseline Noise                  : 1
Aperture                        : 4.5
Megapixels                      : 24.5
Light Value                     : 6.6
Hello,
I am looking directly at the mounted SD-Card. This is very strange. I have no explanation for this. What OS do you use?
I'm using debian (testing) on amd64 architecture.
BTW, your SL2-S internal serial number is 0041, mine is 0039 🙂
regards
Reiner
8 hours ago, stallus said:
Hello,
regards
Reiner
I am using Mac OS X, looking at the data before and after import. Maybe there is a bug that can be fixed by resetting the camera?
Cheers,
- Srdjan
File Size                       : 43 MiB
File Type                       : DNG
Software                        : 2.12
Artist                          :
Image Width                     : 6048
Image Height                    : 4048
X Resolution                    : 300
Y Resolution                    : 300
White Level                     : 16383
Rating                          : 0
Copyright                       :
F Number                        : 4.5
ISO                             : 320
Exif Version                    : 0231
File Index                      : 108
Film Mode                       :
Color Space                     : sRGB
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Lens Make                       : SIGMA
Baseline Noise                  : 1
Aperture                        : 4.5
Megapixels                      : 24.5
Light Value                     : 6.6
Why your image size: 6048x4048
and mine:
Image Size                      : 6000x4000
Megapixels                      : 24.0
SL2-S sensor size slightly up or because mine JPG, not DNG?
mine made on 2020.11.09 and yours 2020.11.19 that is 10-days difference btw
and mine:
Megapixels                      : 24.0
Yes, the size "difference" is because of the raw file. Note that once the raw is imported into Adobe's software it is automatically cropped to 6000 x 4000. The extra pixels around the edge are likely useless and therefore are thron away. This is typical for most cameras, AFAIK.
Edited by SrMi
They aren't useless, they are used for debayering of the edge pixels that are in the image. They may also be used for distortion correction, but I'm not sure about that.
vor 3 Stunden schrieb SrMi:
Cheers,
- Srdjan
I think the reason for this behavoir is a bug in the exFAT implementation in the linux kernel and in the exFAT-fuse driver.
There seems to be a fix for the exFAT-fuse driver. But there is no release yet. 😞
see the link: https://github.com/relan/exfat/issues/70
So the issue is not on the leica side:-)
  • Thanks 2
Yes. Hasselblads use it also for handling long exposure noise.
vor 2 Stunden schrieb stallus:
Just compiled the patched exFAT-fuse driver. Now the timestamp is interpreted correctly.
After some fighting against autoloading the kernel exfat driver(with timestamp bug)
regards
Reiner
  • 2 weeks later...
Hi, I’m having a problem after installing 3.0 on my SL2, which is my 90MM F2.0 APO no longer works (I get a lens firmware not supported message) whereas my 50MM F2.0 APO works fine (it seemed to do a firmware upgrade when I first attached it to the SL2 with 3.0 firmware).
Has anyone else had this problem for the 90MM?
More important, does anyone know a fix for the problem?
Thanks, Michael
Thanks, Michael
the lens firmware happens automatically when the lens is connected and turned on. Have you tried that?
Thanks, Michael
SL2 or SL2-S? this is the SL2-S firmware thread?
Thanks for the feedback.
I have the SL2 3.0 firmware for my SL2 camera. I did connect my 90mm APO and 50mm APO lenses and turned on the camera for each (a few times). The 50mm did update the firmware but the 90mm did not. So I don’t know if there is a bug with the 3.0 firmware not recognizing and updating for the 90mm or if there is a problem with the 90mm lens itself. The 90mm has been working perfectly for me before with the 2.1 firmware.
On 9/24/2021 at 12:07 PM, SrMi said:
Yes, the size "difference" is because of the raw file. Note that once the raw is imported into Adobe's software it is automatically cropped to 6000 x 4000. The extra pixels around the edge are likely useless and therefore are thrown away. This is typical for most cameras, AFAIK.
No, they're hardly useless.  I'm coming in late to this party, but I noticed in the EXIF dumps from the files shot with the Sigma contemporary 24/3.5 (a very nice lens, BTW) that there is a WarpRectilinear correction applied to undo distortion.  The correction interpolates the captured  pixels back to the larger, non-rectangular but undistorted frame from which they were found in the original image.  Adobe, which treats WarpRectilinear correction as mandatory, then trims the image back to the 400x600 pixels that it feels you want.  C1, in the crop frame, lets you keep as many as you want in the larger corrected image, even if the ratio of edge lengths is no longer exactly 2:3.   C1 also has a slider to let you adjust the amount of correction so that if you think that interpolation has taken something away from your resolution in the corners you can just use the captured image without any correction.  This is a sensible thing to do if there are no straight lines near the edges in your image.
Welcome to the forum, Michael!
You might want to repost this question in one of the SL2 firmware threads.
I have the SL2-S and the 90SL lens but not with me - I will check in a few days - I can't recall if I've used that lens since the SL2-S firmware update, but that was not such a major update as for the SL2.
My 90 Summicron was updated no problem when I connected it to my SL2-s. I suspect the firmware update was not fully completed on yours for some reasons. Have you tried contacting Leica about the issue?
