Cheeky Greggs Posted April 9, 2021 Share #1 Posted April 9, 2021 (edited) Advertisement (gone after registration) Will I break the camera if i move the slow shutter speed dial on the FRONT of the camera BEFORE cocking? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 9, 2021 by Cheeky Greggs Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/319768-will-i-break-the-camera-if-i-move-the-slow-shutter-speed-dial-on-the-front-of-the-camera-before-cocking/?do=findComment&comment=4178207'>More sharing options...
Advertisement Posted April 9, 2021 Posted April 9, 2021 Hi Cheeky Greggs, Take a look here Will I break the camera if i move the slow shutter speed dial on the FRONT of the camera before cocking?. I'm sure you'll find what you were looking for!
jdlaing Posted April 10, 2021 Share #2 Posted April 10, 2021 You should cock the shutter before setting shutter speed. The dial would spin before the shutter is cocked. Link to post Share on other sites More sharing options...
TomB_tx Posted April 10, 2021 Share #3 Posted April 10, 2021 While the front (slow speed) dial doesn't spin, the Leica IIIc owner's manual states that it is "most important" to set the top (fast speed) dial to to the "30-1" index BEFORE adjusting the slow speed dial. Since the top dial can't be correctly set before winding the shutter, this assumes the shutter is wound first. In the summary table for "setting shutter speeds" the sequences vary a bit. For setting fast speeds it notes 1. Set slow speed dial at 30; 2. Wind shutter, lift...and set fast speed dial. But for slow shutter speeds it says 1. Wind shutter and set top speed dial to 30-1; 2. Set slow speed dial So it sounds like you won't break the camera if you move the slow speed dial before winding the shutter, but maybe the slow speed time needs to be set last for it to be accurate. Link to post Share on other sites More sharing options...
Michael Geschlecht Posted April 12, 2021 Share #4 Posted April 12, 2021 Hello Cheeky, Welcome to the Forum. The reason that it is important for the shutter to be cocked before setting the slow speed dial is that the slow speed mechanism requires the first curtain be entirely open without the second curtain being released in order for the slow speed mechanism to operate properly. At any speed faster than the slowest high speed the first & second curtains begin to travel together, as a pair, before the first curtain is entirely open. Winding the shutter first allows the photographer to make sure that the high shutter speed dial is set to the lowest high speed. This is because for the slow speed mechanism to operate properly the first curtain has to open entirely across the frame without the second curtain beginning to run. This only occurs when the high speed dial on the top is set to the slowest numerical setting which is 20 - 1 on the IIIa in your photo. Then the timing mechanism controlled by the slow speed dial on the front can correctly time the exposure at the end of which time the second curtain is released. If a different setting is set on the high speed dial then the exposure will not be correct. Whether or not it damages the camera. Best Regards, Michael Link to post Share on other sites More sharing options...
