1 hour ago, Photoworks said:
It works for me every time.  It just a tag in the Metadata and the processing software should pick it up, the only time the signal get confuse is when you shoot strait up and down
Mine don't turn automatically ...
25 minutes ago, beewee said:
I don’t think there’s a way to actually disable auto-rotation. What software are you using to view your photos?
As you can see i took this photo vertically but when i play view it not turning. Is this normal? Even Q had it.
Yes, that’s normal for the camera display. If it rotated on the camera screen the image would look VERY small. Auto rotate is meant for images downloaded to other devices like your phone or computer.
Really? My Q 1 had auto rotation. Which had smaller screen
3 minutes ago, LD_50 said:
It’s obvious people want to review the image in the orientation they shot it and intend to view it.  Most cameras I’ve owned have this option.
So Sl2s dont have it? Yes you are correct. All my other camera had this functionality
4 hours ago, Hotdoug said:
wow....... they should leave as option.....
you realize that a rotated image will be fitter to the screen size, so that it be displayed 1/2 size of what you have now. I think you are the only one here that want that.
I know I had this option in past cameras, never liked it, always turned it off. In my opinion it is a crappy and very inconsistence way to work.
So, for me it is perfectly fine how it is. However, I agree, they should give the user the choice to make the decision.
Cheers
Daniel
Is rotating your SL2-S through 90 degrees to chimp a problem?  You have to do it to take a picture in portrait orientation.  If the camera's attached to a tripod there's always this option.
Pete.
  • Haha 1
