Elmar vs Summicron
sm23221
x
I find that I use it a lot more than the 'cron. It is small, light and reasonably fast and very sharp. My only 'dislike' with it is that it doesn't have a focusing tab.
I recently had an M8 image shot with the Elmar enlarged to 70x100cm, no problem. Here is a link to a shot I posted in a thread from May.
http://www.l-camera-forum.com/leica-forum/leica-m8-forum/25677-elmar-50-2-8-poor-mans-2.html#post269066
- Carl
There was a 50s review in LFI last year, and they found that the Cron was slightly sharper, but they were pretty similar. I could dig it out if you like.
at short distances the elmar is said to be slightly better (even better than the 50/1.4asph) at comparable f-stops
How does the 50mm Elmar 2.8 compare with the Summicron 2.0 as far as image quality?
If you want a collapsible and compact 50mm lens, Voigtlander Heliar 2/50 may also be a good choice. According to Popular Photography its performance is in every way comparable to the Summicron 2/50 at all f stops. I have also been unable to see any difference in optical quality, and build quality is also second to none. Price is crazy to at about $400.
I'm considering buying one before it's discontinued. I have the Summicron but like the idea of the compactness of the Elmar; it seems like it would fit nicely in a fanny pack which is what I use to tote my camera & lenses around with. I just didn't want to compromise image quality. Carsten, I'll search for that article - thanks.
Bottom line is Leica designs (or at least used to design) all of their M lenses to be totally usable wide open. Generally, the lens improves to its maximum performance on stopping down one or two stops. And you can take that to the bank for the current and earlier M-mount lenses. However, there were always a few exceptions that performed so well wide open, they get only very slightly better stopped down -- the Summicron 50 and 35 and Elmar 50 and 90 are examples. That said, if you shoot your 50's at f4, you will not notice any difference between the Cron and the Elmar. At f2.8, the Cron will be a bit better, and of course at f2, the Cron kicks the Elmar's butt :)
If you want compact and the best all-around performance, the Cron is the choice. If you want the most compact with great perfromance, the Elmar is the one. If you don't care about size or cost, then the Summilux offers outstanding wide open performance and is equal to the other two by f4 as well.
With digital's excellent high ISO performance (even the M8's relative to film), the uber-fast lenses are not really needed to capture images in limited light. The big difference however, is: with the cropped sensor, DoF lengthens at the same image magnification as for full-frame (we have to drop down one focal spacing for the same image magnification). So even faster lenses are needed to create a paper-thin DoF look in an image. Unfortunately, there is no free lunch.
Cheers,
Guest tummydoc
I'm constantly reminding myself of that fact whenever a sales rep offers me one :D
Your comments re: the fifties are spot-on. Leica hasn't a bad apple in the bunch, it's merely a choice of paying the price in currency and weight for each added f-stop.
