dealy663 Posted January 24, 2021 Share #1 Â Posted January 24, 2021 Advertisement (gone after registration) Hi I just received a used frankenfinder from KEH. I mounted it up to my camera today and even with the locking wheel tightened the finder is loose, not in the hot shoe, but it swivels from side to side a bit on the post that goes through the locking wheel. I assume this is not how it's supposed to be, it kinda flops around a bit if I move the camera. Does anyone know if there is a way to fix it or will I just have to send it back to KEH and ask for a refund? Â Thanks, Derek Link to post Share on other sites More sharing options...
Advertisement Posted January 24, 2021 Posted January 24, 2021 Hi dealy663, Take a look here Universal Wide Angle Frankenfinder is loose, fixable?. I'm sure you'll find what you were looking for!
jdlaing Posted January 24, 2021 Share #2  Posted January 24, 2021 7 minutes ago, dealy663 said: Hi I just received a used frankenfinder from KEH. I mounted it up to my camera today and even with the locking wheel tightened the finder is loose, not in the hot shoe, but it swivels from side to side a bit on the post that goes through the locking wheel. I assume this is not how it's supposed to be, it kinda flops around a bit if I move the camera. Does anyone know if there is a way to fix it or will I just have to send it back to KEH and ask for a refund?  Thanks, Derek That doesn’t sound normal. Mine locks well with no movement. If after a close inspection it can’t be corrected I’d ask for a replacement or refund. Link to post Share on other sites More sharing options...
Luke_Miller Posted January 25, 2021 Share #3  Posted January 25, 2021 Are the four screws that hold the metal shoe to the finder body tight?  Link to post Share on other sites More sharing options...
