Phil A Posted August 9, 2021 Share #21  Posted August 9, 2021 Advertisement (gone after registration) The Sigma 500 f/4 for DSLR has fantastic IQ and acceptable AFc but at 64 years I found it too heavy for me to lug around at sport or on safari. Weight was the main reason I switched from Canon to the SL2/M10. I love my 90-280 but it is too short for small or distant wildlife. I wouldn't hesitate to get the 150-600 for the times when I need that extra reach.   1 Link to post Share on other sites More sharing options...
Advertisement Posted August 9, 2021 Posted August 9, 2021 Hi Phil A, Take a look here Using the SL2 for Wildlife?. I'm sure you'll find what you were looking for!
V23 Posted August 12, 2021 Share #22 Â Posted August 12, 2021 I thought about the same issue, should I decide that I want some longer telephoto for wildlife/bird photography I would not tinker with Leica and would get Nikon or Canon. Performance would overcome brand loyalty. Link to post Share on other sites More sharing options...
jaapv Posted September 10, 2021 Share #23  Posted September 10, 2021 This topic has become obsolete The Sigma 150-600 is the gamechanger. IQ is outstanding and the AF very good. 1 Link to post Share on other sites More sharing options...
sillbeers15 Posted September 10, 2021 Share #24 Â Posted September 10, 2021 3 hours ago, Artin said: I have not done much with photography in the past 2 years but now picked up the camera again , that sounds intriguing. I may just pick up a 150-600Â In the event that you do decide to pick up or test the Sig150-600mm, kindly provide feedback on it's AFC comparing to your Canon 400mm 2.8 or other lenses. I found that the success rate on getting sharp pics on SL2 with AFC works on Sig 150-600mm but success rate is much lower than SL90-280mm. I'm not sure if it were due to Sig 150-600mm limitation or is is common over longer telephoto lenses that AFC success rate reduces on general? Link to post Share on other sites More sharing options...
michali Posted September 10, 2021 Share #25  Posted September 10, 2021 1 hour ago, sillbeers15 said: In the event that you do decide to pick up or test the Sig150-600mm, kindly provide feedback on it's AFC comparing to your Canon 400mm 2.8 or other lenses. I found that the success rate on getting sharp pics on SL2 with AFC works on Sig 150-600mm but success rate is much lower than SL90-280mm. I'm not sure if it were due to Sig 150-600mm limitation or is is common over longer telephoto lenses that AFC success rate reduces on general? The Canon mounted on the SL2 via the MC-21 adapter only gives you AFS, AFC isn't available. I also think that AFC is more efficient with shorter focal lengths & is generally slower with longer focal lengths. 2 Link to post Share on other sites More sharing options...
jaapv Posted September 10, 2021 Share #26  Posted September 10, 2021 I only use AFC on a long lens with tracking -which is difficult enough at 600 mm anyway. 1 Link to post Share on other sites More sharing options...
sillbeers15 Posted September 10, 2021 Share #27  Posted September 10, 2021 Advertisement (gone after registration) 1 hour ago, jaapv said: I only use AFC on a long lens with tracking -which is difficult enough at 600 mm anyway. I'm trying out AFS / Field combination shooting BIF to see if the sharp pics success rate can improve? Yet to conclude. Previously on SL90-280mm, applying AFC / Tracking combined with viewing through a dot sight device attached on the SL2's hotshoe provided me good AF success rate. 1 Link to post Share on other sites More sharing options...
