beosoundfan_ Posted May 18, 2021 Share #21 Posted May 18, 2021 (edited) Advertisement (gone after registration) vor 22 Stunden schrieb WimDel: Yes I noticed that too, while scanning the sky for migratory birds. Indeed using B-mode calibration certainly made a difference. Although I find it not the most comfortable way of calibrating, constantly putting the lenscap on and off. Do you get another result (or at least the same as with B), when you press the plus button in order to force a recalibration in A mode? Edited May 18, 2021 by beosoundfan_ Link to post Share on other sites More sharing options...
Advertisement Posted May 18, 2021 Posted May 18, 2021 Hi beosoundfan_, Take a look here Calonox View USB-C port has strange limitation . I'm sure you'll find what you were looking for!
cloudburst Posted May 18, 2021 Share #22 Posted May 18, 2021 53 minutes ago, beosoundfan_ said: Do you get another result (or at least the same as with B), when you press the plus button in order to force a recalibration in A mode? I found that doing an A or M mode calibration actually made the artefact return LOL I was on the phone to the head of Leica in the UK the other day. He checked his device (which actually used to be mine) and it is exactly the same. He said it was normal. CB Link to post Share on other sites More sharing options...
NZWatcher Posted June 9, 2021 Share #23 Posted June 9, 2021 Hi I am having issues trying to get my Android App and my View to mate up and receive the latest Firmware update I have Pulsar also and have no issues with them but this Calonox when I tap the connect button on App goes to my wifi setting page in my phone Peter - New Zealand Link to post Share on other sites More sharing options...
cloudburst Posted June 9, 2021 Share #24 Posted June 9, 2021 2 hours ago, NZWatcher said: Hi I am having issues trying to get my Android App and my View to mate up and receive the latest Firmware update I have Pulsar also and have no issues with them but this Calonox when I tap the connect button on App goes to my wifi setting page in my phone Peter - New Zealand Hi Peter, the Leica Calonox View creates a WiFi hotspot of its own which you need to connect your device to. That’s why it’s taking you to the settings page. CB Link to post Share on other sites More sharing options...
NZWatcher Posted June 9, 2021 Share #25 Posted June 9, 2021 7 hours ago, cloudburst said: Hi Peter, the Leica Calonox View creates a WiFi hotspot of its own which you need to connect your device to. That’s why it’s taking you to the settings page. CB I will try again and let you know - so should I disconnect from my home Wifi I did also note that it would not get as far as it did if my Mobile connection was on I have done all the Pulsars before with no issues Link to post Share on other sites More sharing options...
cloudburst Posted June 9, 2021 Share #26 Posted June 9, 2021 26 minutes ago, NZWatcher said: I will try again and let you know - so should I disconnect from my home Wifi I did also note that it would not get as far as it did if my Mobile connection was on I have done all the Pulsars before with no issues Yep. Turn on Wifi on the Calonox and then connect to that Wifi network instead of the one you normally connect to. Then start the app, go to device storage to see the photos you’ve taken. Then, once finished, connect back to your original Wifi network and turn Wifi off on the Calonox. CB Link to post Share on other sites More sharing options...
NZWatcher Posted June 10, 2021 Share #27 Posted June 10, 2021 Advertisement (gone after registration) 6 hours ago, cloudburst said: Yep. Turn on Wifi on the Calonox and then connect to that Wifi network instead of the one you normally connect to. Then start the app, go to device storage to see the photos you’ve taken. Then, once finished, connect back to your original Wifi network and turn Wifi off on the Calonox. CB No Tried many options for 20 mins or more I can get live coverage over app - I can find Files with photos and Vids (but not via the two main Buttons on App Dashboard - need to go to Files Folders) So - I go to the Gear wheel That take me to the next page of App Asks for Password and ssid # ) so put them in from unit When I click on next button asking for Choose Firmware - it goes to a File log like Explorer and shows all my other Apps in phone etc Nothing happens if i click Start upgrade Something is not Mating up between the two Also how does my App get the latest Firmware update if not connected to my ISP Wifi (I tried having both Calonox and my ISP Wifi connected at same time but it was not I think Link to post Share on other sites More sharing options...
cloudburst Posted June 10, 2021 Share #28 Posted June 10, 2021 (edited) 9 hours ago, NZWatcher said: No Tried many options for 20 mins or more I can get live coverage over app - I can find Files with photos and Vids (but not via the two main Buttons on App Dashboard - need to go to Files Folders) So - I go to the Gear wheel That take me to the next page of App Asks for Password and ssid # ) so put them in from unit When I click on next button asking for Choose Firmware - it goes to a File log like Explorer and shows all my other Apps in phone etc Nothing happens if i click Start upgrade Something is not Mating up between the two Also how does my App get the latest Firmware update if not connected to my ISP Wifi (I tried having both Calonox and my ISP Wifi connected at same time but it was not I think You would have to separately obtain the firmware update file from Leica (assuming a later version to what you have exists) and place that in your Android filesystem. Then point to it from the firmware update process in the Calonox app. This (manual) process is fairly common for firmware updates and is what I’m familiar with doing for various synthesizers, network boxes etc that I have. So you can at least connect to your camera and retrieve photos. That’s progress. You won’t be able to connect to two Wifi networks at once, so no point in trying. As a matter of interest, what is driving you to want to update your firmware? CB Edited June 10, 2021 by cloudburst Link to post Share on other sites More sharing options...
NZWatcher Posted June 11, 2021 Share #29 Posted June 11, 2021 Why do I want to do update There is a slight blur in the middle of my picture (like a smudge/finger mark on from lens) I also thought there looks to be a May 2021 Firmware update to be had ?? Link to post Share on other sites More sharing options...
cloudburst Posted June 11, 2021 Share #30 Posted June 11, 2021 5 hours ago, NZWatcher said: Why do I want to do update There is a slight blur in the middle of my picture (like a smudge/finger mark on from lens) I also thought there looks to be a May 2021 Firmware update to be had ?? Interesting re May 2021 firmware update. Can you provide a link to this info, as I hadn’t been aware. Ref the smudge - is this a circular area, centred horizontally and just higher than centre vertically? If so, then it’s not just your unit - we all have it and I too hope an update may cure. Meanwhile a B-mode calibration temporarily sorts it for me. CB Link to post Share on other sites More sharing options...
NZWatcher Posted June 11, 2021 Share #31 Posted June 11, 2021 12 hours ago, cloudburst said: Interesting re May 2021 firmware update. Can you provide a link to this info, as I hadn’t been aware. Ref the smudge - is this a circular area, centred horizontally and just higher than centre vertically? If so, then it’s not just your unit - we all have it and I too hope an update may cure. Meanwhile a B-mode calibration temporarily sorts it for me. CB I will look again - I may have been mistaken about Firmware May 21 ?? OK - I will try the (I presume you meaning Semi Auto Calibration and not Auto) calibration Thanks for your assistance - maybe there is no update and that is why my App wont move to next step Link to post Share on other sites More sharing options...
suricate Posted June 14, 2021 Share #32 Posted June 14, 2021 On 6/9/2021 at 10:18 AM, NZWatcher said: Hi I am having issues trying to get my Android App and my View to mate up and receive the latest Firmware update I have Pulsar also and have no issues with them but this Calonox when I tap the connect button on App goes to my wifi setting page in my phone Peter - New Zealand Hi NZWatcher, Same problem for me : impossible to connect my Leica Calonox App on my smartphone (Nokia, Android 10) with the Calonox View device ! In fact, smartphone and Calonox View look connected (info "connected, no internet access" on my smartphone), but I can not activate the Leica Calonox App on my smartphone (the WiFi button of the app remains gray !) But I could connect the App and use it with an iPhone/IOS !! (And BTW I now have the right date on my photos/videos transferred to my laptop with USB-C cable !) I sent a message to app-support@leica-camera.com, hopping for help... I will report if Leica finds a solution. Link to post Share on other sites More sharing options...
suricate Posted June 14, 2021 Share #33 Posted June 14, 2021 On 5/3/2021 at 8:58 PM, beosoundfan_ said: Hi cloudburst, I just received my Calonox a week ago. It has the build date 2021-04-20. Even it has the same specs as your replacement, I have the exact same issues as you had with your first Calonox. When I switch it off and then on: Zoom reverts back to x1 Brightness level (and icon) reverts to level 4 (very annoying) Heat display mode (eg. Red Hot) is retained, however, icon in menu and status header reverts wrongly to White Hot Contrast reverts to level 1 and has no function at all Video out (if selected) remains on, however, menu slider says off and icon in status header has disappeared Calibration Mode reverts to Auto Connected to a mac it does not detect the Calonox (no drive icon ist shown or mapped) I am a bit frustrated that this happens even to the latest version. Propably I have to go the same way as you and get in contact with the support. Does anyone have the same issues? Is yours really fixed? Or is it a SW-bug? GUI: 5.0 SYS: 20200729194 Boot: V1.3 FPGA: 229 HW: V50B Regards Beo Hi beosoundfan_ (and cloudburst) I received my Calonox View one month ago (with the same system info) and have exactly the same problems, and more I can not connect my Calonox View App on my Android 10 smartphone (Nokia) with the device (App not working, and I have to connect the device with the USB-C / A cable for managing the files on my laptop) ... But the App was working with an iPhone/IOS (and I could get the right dates now for the files) ! Did somebody else get this connection problem with Android App ? I'm still wainting for a response from the app support in Germany. Regards YF Link to post Share on other sites More sharing options...
Shimo Posted December 12, 2021 Author Share #34 Posted December 12, 2021 I'm still wondering whether anybody ever figured out whether Leica actually published a firmware update for the Calonox View. I can't find any information regarding a firmware update on Leicas service pages and I never got a response from Leica. In case someone recently purchased a device I would be interested to know which firmware version the device comes shiped with. Link to post Share on other sites More sharing options...
Shimo Posted December 13, 2021 Author Share #35 Posted December 13, 2021 Am 12.12.2021 um 12:15 schrieb Shimo: I'm still wondering whether anybody ever figured out whether Leica actually published a firmware update for the Calonox View. I can't find any information regarding a firmware update on Leicas service pages and I never got a response from Leica. In case someone recently purchased a device I would be interested to know which firmware version the device comes shiped with. In case someone is interested: I just spoke to someone at Leica software support. He was very nice and helpful and confirmed that (a) so far there is no update for the Calonox View on the market, (b) there shall be an update available sometime beginning of next year, (c) there shall be an update for the Calonox View as well the Calonox Sigth and (d) how this update shall be installed on the device is not yet finally decided upon. The update won't happen through the mobile app. Either there shall be a dedicated Windows package or the update might only be available by autorized service partner. Link to post Share on other sites More sharing options...
cloudburst Posted September 22, 2022 Share #36 Posted September 22, 2022 On 12/13/2021 at 1:53 PM, Shimo said: In case someone is interested: I just spoke to someone at Leica software support. He was very nice and helpful and confirmed that (a) so far there is no update for the Calonox View on the market, (b) there shall be an update available sometime beginning of next year, (c) there shall be an update for the Calonox View as well the Calonox Sigth and (d) how this update shall be installed on the device is not yet finally decided upon. The update won't happen through the mobile app. Either there shall be a dedicated Windows package or the update might only be available by autorized service partner. Looks like (b) hasn’t been met. And ref (d) a good (and growing) portion of the world wouldn’t have Windows anywhere near them! 🙂 CB Link to post Share on other sites More sharing options...
