rjsphd Posted December 9, 2020 Share #1  Posted December 9, 2020 Advertisement (gone after registration) I have not touched my M6 for many months and I had taken out and lost the batteries. What are the recommended batteries for the M6 available today?  (I searched for an answer in English on the site but could not find one.)  Many thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted December 9, 2020 Posted December 9, 2020 Hi rjsphd, Take a look here M6 Battery Recommendation. I'm sure you'll find what you were looking for!
Matlock Posted December 9, 2020 Share #2  Posted December 9, 2020 14 minutes ago, rjsphd said: I have not touched my M6 for many months and I had taken out and lost the batteries. What are the recommended batteries for the M6 available today?  (I searched for an answer in English on the site but could not find one.)  Many thanks in advance. 1 x Duracell 1/3N (2L76).  1 Link to post Share on other sites More sharing options...
nwphil Posted December 9, 2020 Share #3 Â Posted December 9, 2020 or two #357... Â 2 Link to post Share on other sites More sharing options...
Narsuitus Posted December 9, 2020 Share #4 Â Posted December 9, 2020 I have one 3-volt Eveready 2L76 battery in mine. 1 Link to post Share on other sites More sharing options...
plaidshirts Posted December 10, 2020 Share #5  Posted December 10, 2020 Go with a lithium 3V 1/3N or 2L76 as previously recommended. It's a single piece and will last you forever. 1 Link to post Share on other sites More sharing options...
Anbaric Posted December 10, 2020 Share #6 Â Posted December 10, 2020 I would always go with lithium. The double height CR1/3N and 2L76 (etc.) batteries I've seen are lithium, but many LR44 or A76 batteries that need to be used in pairs are alkaline, and are more likely to leak and do expensively bad things to your M6. 1 Link to post Share on other sites More sharing options...
ckuwajima Posted December 10, 2020 Share #7  Posted December 10, 2020 Advertisement (gone after registration) 3 hours ago, Anbaric said: I would always go with lithium. The double height CR1/3N and 2L76 (etc.) batteries I've seen are lithium, but many LR44 or A76 batteries that need to be used in pairs are alkaline, and are more likely to leak and do expensively bad things to your M6. In case of buttom cells, M6 TTL manual recommends using only Silver Oxide batteries: SR44/357. 1 Link to post Share on other sites More sharing options...
andrew01 Posted December 10, 2020 Share #8  Posted December 10, 2020 Here is the manual. Compatible  batteries on page 19. https://www.cameramanuals.org/leica_pdf/leica_m6.pdf I use a lithium battery in mine (1/3N). 2 Link to post Share on other sites More sharing options...
Anbaric Posted December 10, 2020 Share #9 Â Posted December 10, 2020 From the manuals, looks like Leica doesn't recommend LR44 (alkalkine) for the the M6 Classic or the M6 TTL. It's lithium or silver oxide for both. Apart from the risk of leakage, perhaps they don't like alkalkine because of worse discharge characteristics? 1 Link to post Share on other sites More sharing options...
Graham (G4FUJ) Posted December 11, 2020 Share #10  Posted December 11, 2020 I use 1/3N in my M6. Easier to change out in the field if necessary. I once lost an SR44 doing a battery change 😖 Link to post Share on other sites More sharing options...
andrew01 Posted December 11, 2020 Share #11 Â Posted December 11, 2020 Alkaline batteries are the most susceptible to leaking. I would never use them in any camera. Link to post Share on other sites More sharing options...
Bernard Shakey Posted January 5, 2021 Share #12  Posted January 5, 2021 I was using 2 x SR44 unbranded batteries which were not lasting so I changed to Varta CR1/3N which was suggested by Sherry Krauter and much better. I had another issue with the battery cap for my M6- See attached photo. The cheap copy is all metal and the Leica has a small black band on the inside. My problems started when I began using the cheap cap and the power drained in a few days. I don't know but perhaps the black band prevents direct contact with the metal camera body . Worth knowing if someone out there is troubleshooting.   Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/315920-m6-battery-recommendation/?do=findComment&comment=4112578'>More sharing options...
Chuck Albertson Posted January 5, 2021 Share #13 Â Posted January 5, 2021 The 1/3N batts used to be part of the standard battery rack in the local drugstores, but disappeared from that a few years ago. So now they're mostly available online and in camera stores. They also seem to be popular for powering laser gun sights, so if you're in the States, try your neighborhood gun shop. 1 Link to post Share on other sites More sharing options...
Lisa Davidson Posted April 13, 2021 Share #14  Posted April 13, 2021 Now that you mention it, how on earth do you remove the battery compartment cover? I had the impression that it screws on and off, but it's not going to move. Thank you. Link to post Share on other sites More sharing options...
TomB_tx Posted April 13, 2021 Share #15  Posted April 13, 2021 (edited) The cover should unscrew easily. If stuck it may mean a battery was left in and leaked, leaving residue in the threads of the cover. Never leave batteries in cameras stored for long. My old M6 needed a new meter board and other parts replaced because of battery leakage, and I’ve seen many film cameras with battery covers corroded in place. Maybe a rubber pad can get a better grip on the cover to loosen it. Edited April 13, 2021 by TomB_tx Link to post Share on other sites More sharing options...
davidmknoble Posted June 29, 2021 Share #16  Posted June 29, 2021 On 4/12/2021 at 9:19 PM, TomB_tx said: The cover should unscrew easily. If stuck it may mean a battery was left in and leaked, leaving residue in the threads of the cover. Never leave batteries in cameras stored for long. My old M6 needed a new meter board and other parts replaced because of battery leakage, and I’ve seen many film cameras with battery covers corroded in place. Maybe a rubber pad can get a better grip on the cover to loosen it. I know this post is 2 months old, but as  long time film M user, I always purchase the second variety battery cap from Leica with the slot.  A US Quarter will fit nicely and loosen and tighten the battery cap.  Depending on temperature and humidity when you tighten the cap, it can get stuck and hard to remove, just like a filter on a lens.  So, the slot means it can be removed easily.  I always keep the original cap in case I want to trade later... Hope this helps.  2 Link to post Share on other sites More sharing options...
