BlueIn2Red Posted November 5, 2020 Share #1  Posted November 5, 2020 Advertisement (gone after registration) Hi guys, I think I know the answer, but will a post-late firmware update Leica lens operate as "unrecognised" on the M8/8.2? I'm thinking specifically of the 28mm Summaron, if that makes any difference. I fear it may exhibit oddly coloured corners for example? Link to post Share on other sites More sharing options...
Advertisement Posted November 5, 2020 Posted November 5, 2020 Hi BlueIn2Red, Take a look here Newer 6 bit coded lenses on M8. I'm sure you'll find what you were looking for!
lct Posted November 5, 2020 Share #2  Posted November 5, 2020 26 minutes ago, BlueIn2Red said: Hi guys, I think I know the answer, but will a post-late firmware update Leica lens operate as "unrecognised" on the M8/8.2? I'm thinking specifically of the 28mm Summaron, if that makes any difference. I fear it may exhibit oddly coloured corners for example? It should not given that corners are cropped by M8/M8.2 cameras but i have no experience with this lens sorry. Now you may wish to disguise the 28/5.6 (001011) as 28/2.8 v3 (000011) by simply whitening the third coding pit possibly. Just a stupid idea... 1 Link to post Share on other sites More sharing options...
heinzkraft Posted November 5, 2020 Share #3 Â Posted November 5, 2020 I have the same problem. My 2,4/75 is not recognized, because the last firmware is from 2014. I have asked at Leica Customer Service yesterday, if i should code it as 2,5/75. They denied. It works good and so I ll use it unrecognized (though coded for later M-Cams). Â Link to post Share on other sites More sharing options...
BlueIn2Red Posted November 5, 2020 Author Share #4 Â Posted November 5, 2020 Yeah the longer lenses aren't a problem, 35 and wider can be though. I guess I'll go with post-processing correction if it's a significant issue. Link to post Share on other sites More sharing options...
