Olivier76 Posted October 19, 2020 Share #1  Posted October 19, 2020 Advertisement (gone after registration) Hello, I was wondering what to use to clean the magnesium/metal part of the silver M8 body ? advise requested 👍 Thank you Link to post Share on other sites More sharing options...
Advertisement Posted October 19, 2020 Posted October 19, 2020 Hi Olivier76, Take a look here Cleaning the Silver M8. I'm sure you'll find what you were looking for!
pedaes Posted October 19, 2020 Share #2  Posted October 19, 2020 1 hour ago, Olivier76 said: Hello, I was wondering what to use to clean the magnesium/metal part of the silver M8 body ? advise requested 👍 Thank you Follow the advice in the manual plus common sense (no abrasives or liquids). Link to post Share on other sites More sharing options...
tobey bilek Posted November 9, 2020 Share #3  Posted November 9, 2020 That leaves out most everything.  I have seen Leica techs moisten/dampen a cloth with alcohol.  Not so much it can run inside. When I clean a gun,  I put solvent on a small cloth and wrap it around an apporiate object to get into corners.  On an M,  that would be around shutter dial and advance lever.  Toothpick or tweezers bent at the end are ok.  Use enough layers so metal will not scratch.  Wood is best. Link to post Share on other sites More sharing options...
jdlaing Posted November 9, 2020 Share #4  Posted November 9, 2020 Zeiss alcohol wipes. There is not enough liquid to run but enough to clean. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/314329-cleaning-the-silver-m8/?do=findComment&comment=4077032'>More sharing options...
earleygallery Posted November 9, 2020 Share #5 Â Posted November 9, 2020 Try baby wipes. Link to post Share on other sites More sharing options...
boojum Posted November 9, 2020 Share #6  Posted November 9, 2020 1 hour ago, jdlaing said: Zeiss alcohol wipes. There is not enough liquid to run but enough to clean. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I wonder if the inexpensive eyeglass wipes would do the same job. I have plenty of them. And can get them at my local Costco. I am sure all other mass merchandisers carry them. Link to post Share on other sites More sharing options...
jdlaing Posted November 9, 2020 Share #7  Posted November 9, 2020 (edited) Advertisement (gone after registration) 39 minutes ago, boojum said: I wonder if the inexpensive eyeglass wipes would do the same job. I have plenty of them. And can get them at my local Costco. I am sure all other mass merchandisers carry them. The Zeiss are very inexpensive and consistently reliable. 07 cents each. Walmart, Costco, drug stores. Edited November 9, 2020 by jdlaing 1 Link to post Share on other sites More sharing options...
Olivier76 Posted December 21, 2020 Author Share #8  Posted December 21, 2020 Thank you for your answers. So Lens Wipe mostly ? Ok, I’ll give a try 1 Link to post Share on other sites More sharing options...
a.noctilux Posted May 5, 2021 Share #9  Posted May 5, 2021 Used toothbrush can be handy to clean dusty corners, before blowing, then wipe. Miracle longlast clean at last, when I use a tiny dab of 'Pliz Fée du Logis' borrowed from my wife's panoply. Link to post Share on other sites More sharing options...
NigelG Posted May 5, 2021 Share #10  Posted May 5, 2021 For the dusty bit around the dial/hotshot I’ve used (very carefully) a squishy thing called “cyber clean” I think - bright yellow v.lightly sticky “blob”. Link to post Share on other sites More sharing options...
