5 minutes ago, vwillrocku said:
Over 90%. This problem is not happen today but after the first repairing. It appears randomly and I am sure it is not dependent to the battery capacity. Leica thinks it is normal, this is the reason I cannot trust their service.
So the question begging to be asked is, is it normal? I don't have a digital M to try, but plenty of folks here do.
Edited by malligator
7 minutes ago, Herr Barnack said:
Looks like an empty battery icon.
Yes, an empty battery icon even though every time it shuts down, the battery is far from empty. Sometimes it even happens at the beginning of shooting session which is near 100% battery capacity.
Edited by vwillrocku
vor 25 Minuten schrieb vwillrocku:
Just stumbled across this thread. Doesn‘t sound promising... 🤔
Based on the battery Icon , I would try using another battery. One might think of a corrupted battery whose voltage collapses as soon as some power (current) is required but shows proper voltage otherwise.
Good idea and thanks.
Sadly but I have only one battery. It is too exhausted to test every thing and I soon become a product tester rather than a photographer.
5 minutes ago, jdlaing said:
To me, after looking at the video, it looks like you are overloading the buffer taking so many shots in rapid succession. That will lock up the camera.
Thanks for your input. In many cases it shuts down even I took one or two pictures. I don't think one or two pictures could overload the buffer.
Besides, I never see a modern camera would shut down when the buffer is overload. They only refuse to take more pictures.
@jdlaing Do you have an M10? Would you mind to test some shots with the speed similar to the video to see what happen?
What memory card are you using?
Guest Nowhereman
4 hours ago, vwillrocku said:
...it was bought in Europe and I am now in Asia.
I bought several Leica-M cameras (consecutively) in Paris, while living in Thailand, and had no problem speaking with customer service in Germany. You can telephone just as inexpensively from Asia as from anywhere else in the world by using Skype. And my feeling is that the best thing to do is to telephone and explain the issue...
____________________
Frog Leaping photobook
One more observation to share: sometimes I could take over 10 photos rapidly (much faster than the video) without any problem. So if the problem is the buffer, then the problem should repeat easily as every DNG is almost the same size and the buffer size is constant. But actually it occurs randomly.
3 minutes ago, vwillrocku said:
Sandisk Extreme Pro 128GB
Try a 16 or 32 gig card. The Extreme Pro cards are very good but the Leica image engine only writes to a given speed and the extra speed is wasted on some of the high speed cards. Leica never was a run and gun camera and many here on the forum have found out over the years. If you go past the limits on the buffer, even for a couple or three shots i would expect it to protest.
OK, I will try that if there is no more ways to go. Thanks for your kind reply.
Sometimes if the camera gets close to, or overheats, it will give problems too.
Yes, I also heard Leica is not a fast shooting camera. But as I mentioned before, it can shut down even with one or two photos. But I will try another SD card anyway.
I also wonder if it is related to heat before. But it even happens at the beginning of shooting session when the camera is cool. So it is not temperature dependent. When the camera is hot, the major problem I face is the LV button jammed and hard to be pressed or refuse to rebound. This is the problem Leica unable to fix.
It’s good practice, as I and others have discovered, to always format the card in the camera as well. There are many proponents of a program called SDFormatter in a computer first and then use the camera. I have used cards right out of the package, formatted in camera and never had a problem.
Thanks for your advice. I have to say I always format the card in my cameras.
