hirohhhh Posted September 11, 2020 Share #1 Posted September 11, 2020 (edited) Advertisement (gone after registration) I noticed I have a bit of vignetting on my new SL2 with 24-90 lens with built-in profile enabled in Lightroom. I can correct it manually, but I'm wondering if others have the same issue. It's hardly visible on the busy photos, but I went to the very foggy beach today where the background was mostly solid white and there I can clearly notice darker corners on every photo. Can't say for sure now, but I think I would notice if this was the issue on the SL. Edited September 11, 2020 by hirohhhh Link to post Share on other sites More sharing options...
Advertisement Posted September 11, 2020 Posted September 11, 2020 Hi hirohhhh, Take a look here SL2 Vignetting. I'm sure you'll find what you were looking for!
Photoworks Posted September 12, 2020 Share #2 Posted September 12, 2020 Is it solid corners? Can you post a photo? Link to post Share on other sites More sharing options...
hirohhhh Posted September 12, 2020 Author Share #3 Posted September 12, 2020 (edited) Ok, this is the obvious example with clear corners. The photo was taken with SL2 Multishot and 24-90 Leica L mount lens. And then I applied some random Zeiss lens profile, just to try to remove vignetting. Of course, I don't want to apply random lens profiles to the photos, this was just a test, so I'm wondering if this is an issue with SL2, or it's just my case. Built-in profile Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Zeiss Profile Edited September 12, 2020 by hirohhhh Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Zeiss Profile ' data-webShareUrl='https://www.l-camera-forum.com/topic/313238-sl2-vignetting/?do=findComment&comment=4044450'>More sharing options...
LeicaR10 Posted September 12, 2020 Share #4 Posted September 12, 2020 (edited) Hirohhh, Your Leica 24-90 has some minor vignetting at the 24mm FL, but not much. Based on my past experience with the lens, I don't think there is anything wrong with the lens. I wouldn't use a Zeiss profile but rather use the LR Vignetting tool. Others may have another opinion. r/ Mark Edited September 12, 2020 by LeicaR10 Link to post Share on other sites More sharing options...
SrMi Posted September 12, 2020 Share #5 Posted September 12, 2020 (edited) There is minor vignetting when shooting wide open, it disappears (mostly?) when shooting at f/5.6 or higher. Agree with LeicaR10 that you should only use manual vignetting correction. P.S.: are you using the correct lens hood and no filters? Edited September 12, 2020 by SrMi Link to post Share on other sites More sharing options...
Photoworks Posted September 12, 2020 Share #6 Posted September 12, 2020 that is just character of the lens, it is beautiful . Do you really want a clinical image? I even keep all my vignetting on the noctilux Link to post Share on other sites More sharing options...
hirohhhh Posted September 12, 2020 Author Share #7 Posted September 12, 2020 Advertisement (gone after registration) 4 hours ago, SrMi said: There is minor vignetting when shooting wide open, it disappears (mostly?) when shooting at f/5.6 or higher. Agree with LeicaR10 that you should only use manual vignetting correction. P.S.: are you using the correct lens hood and no filters? Oh, I use PolarPro UV filter. I totally forgot it, I never take it down. I'll try without, maybe that causes the vignetting issue. Link to post Share on other sites More sharing options...
hirohhhh Posted September 12, 2020 Author Share #8 Posted September 12, 2020 37 minutes ago, Photoworks said: that is just character of the lens, it is beautiful . Do you really want a clinical image? I even keep all my vignetting on the noctilux I totally hear you, but I have to say, from my expensive SL lenses - yes, I'd love to have the clean image and if I really like the vignetting, I'll add it (rather than remove it). I have a few old vintage lenses for the character Link to post Share on other sites More sharing options...
SrMi Posted September 12, 2020 Share #9 Posted September 12, 2020 The "perfect" APO-Summicron-SL 35mm f/2 ASPH also vignettes wide open. It would be nice to have an option to correct vignetting automatically, but I do not like to have a mandatory vignetting correction. Link to post Share on other sites More sharing options...
SrMi Posted September 12, 2020 Share #10 Posted September 12, 2020 1 hour ago, hirohhhh said: Oh, I use PolarPro UV filter. I totally forgot it, I never take it down. I'll try without, maybe that causes the vignetting issue. Let us know if it reduces vignetting, though slight vignetting should be expected. Link to post Share on other sites More sharing options...
Jared Posted September 13, 2020 Share #11 Posted September 13, 2020 On 9/11/2020 at 5:53 AM, hirohhhh said: I noticed I have a bit of vignetting on my new SL2 with 24-90 lens with built-in profile enabled in Lightroom. I can correct it manually, but I'm wondering if others have the same issue. It's hardly visible on the busy photos, but I went to the very foggy beach today where the background was mostly solid white and there I can clearly notice darker corners on every photo. Can't say for sure now, but I think I would notice if this was the issue on the SL. A little vignetting is perfectly normal. The profiles aren’t perfect. They don’t, for example, vary with subject distance even though the amount of vignetting in a lens DOES vary with subject distance. The profiles only vary with aperture and focal length. And even then, you can run into issues with more extreme stretches/exposure adjustments that can create concentric circles of brightness. It can be a real pain in astrophotography—not easily corrected with flat fields. The Summicron SL’s actually shows even more vignetting than the 24-90, but that’s because they don’t embed corrections of any sort into the files. I think you’ll find the same issue existed on the SL. It’s better to leave a little vignetting in place at certain apertures and subject distances than to risk over correcting since that generally looks odd to the eye. Link to post Share on other sites More sharing options...
