brunner Posted June 19, 2020 Share #1 Â Posted June 19, 2020 Advertisement (gone after registration) Hello Is anybody using the Summaron 28 5.6 with an UV Filter? My question is: Will the screw on hood fit also when a filter sits on the lens? Thank you Stephan Link to post Share on other sites More sharing options...
Advertisement Posted June 19, 2020 Posted June 19, 2020 Hi brunner, Take a look here Summaron 28 5.6 Filter. I'm sure you'll find what you were looking for!
DickieT Posted June 19, 2020 Share #2 Â Posted June 19, 2020 Hi Stephan - yes it does fit as the filter (A36) steps down on the other side again. You just need to keep the screw of the filter in a different position than the one on the hood. For example one at 12h and one at 3h Link to post Share on other sites More sharing options...
wattsy Posted June 19, 2020 Share #3 Â Posted June 19, 2020 You can screw the filter in with the hood already in place. Link to post Share on other sites More sharing options...
brunner Posted June 19, 2020 Author Share #4 Â Posted June 19, 2020 Thank you very much! Link to post Share on other sites More sharing options...
wattsy Posted June 20, 2020 Share #5  Posted June 20, 2020 Just to clarify, Stephan, I was referring to the modern M mount 28mm Summaron (your question being in the M lens subform). Dickie was, I think, referring to the original screw mount version of the lens. With the modern lens, the hood will not mount over the filter (E34 size) but the filter can be screwed in with the hood already in place. Link to post Share on other sites More sharing options...
brunner Posted June 20, 2020 Author Share #6 Â Posted June 20, 2020 Thank you Ian. Yes, I asked for the newer M version... Link to post Share on other sites More sharing options...
mr_bom Posted July 4, 2020 Share #7  Posted July 4, 2020 Advertisement (gone after registration) Just curious which body do you use the lens with? I have an issue with the lens on M7.  thanks Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/310707-summaron-28-56-filter/?do=findComment&comment=4003827'>More sharing options...
ianman Posted July 4, 2020 Share #8 Â Posted July 4, 2020 46 minutes ago, mr_bom said: Just curious which body do you use the lens with? MP, M4-P, M9. 1 Link to post Share on other sites More sharing options...
jakontil Posted July 6, 2020 Share #9  Posted July 6, 2020 I use mine on M10 bodies Link to post Share on other sites More sharing options...
