Ken Chuang Posted June 19, 2020 Author Share #21 Posted June 19, 2020 Advertisement (gone after registration) On 6/14/2020 at 12:13 PM, RoySmith said: To see how much vignetting is being removed by the Software Correction that is automatically applied by programs like Adobe Lightroom, you could run the DNG through DNG Cleaner before importing them into Lightroom to remove the opcodes and see if the vignetting appears. Just checked out DNG cleaner, looks like a cool app to try.. most likely give it a try over the weekend. Link to post Share on other sites More sharing options...
Advertisement Posted June 19, 2020 Posted June 19, 2020 Hi Ken Chuang, Take a look here dark shadow on four corners, is it the lens hood? . I'm sure you'll find what you were looking for!
jaapv Posted June 19, 2020 Share #22 Posted June 19, 2020 23 hours ago, Ken Chuang said: The reason why I said about LR is due to the fact that there are quite some LR online courses and presets for sales. Creating a perception that there is high traction In using LR. In fact, there is even more for Photoshop Presets for PS less People tend to create their own actions, profiles, etc. ON1 has extensive Video instructions.n A presets library as well. 1 Link to post Share on other sites More sharing options...
LTFS Posted September 5, 2020 Share #23 Posted September 5, 2020 It disappears if you download the right modules in DxO Photolab 3. It's not the lens hood. Link to post Share on other sites More sharing options...
ianforber Posted September 5, 2020 Share #24 Posted September 5, 2020 This does just look like the uncorrected DNG image - it’s similar to what I get if I open a Q2 file in Luminar or turn off the auto-correct option in Capture One (I don’t use LR anymore). That said, I haven’t taken pictures with and without the lens hood attached so can’t be 100% certain it isn’t a contributory factor, I just don’t get any corner shading when importing into Capture One with auto-correction turned on. Link to post Share on other sites More sharing options...
Leica Guy Posted September 19, 2020 Share #25 Posted September 19, 2020 (edited) Looks like to me it could be the filter and not lens hood. Too thick a filter will cause vignetting. Edited September 23, 2020 by Leica Guy Link to post Share on other sites More sharing options...
Jared Posted September 20, 2020 Share #26 Posted September 20, 2020 I’d say there is more than one thing going on. First, it appears that the embedded op codes are not being used in your previews or when you import DNG’s into Photos. That is weird—I can’t explain that. They should be used in all cases. There are a few software programs that will allow you to ignore the embedded lens profile, but they are the exception not the rule. The lens on the Q2 has a lot of distortion. A lot. That is intentional. It allows the lens to be smaller and lighter and contain fewer lens elements. The op codes (embedded lens profile) then allow the software to stretch the image to correct for distortion, crop to rectilinear result, and interpolate back to the original 47 megapixels. That process stretches the extreme corners out of the final image, so the vignetting disappears. It is being cropped out in Lightroom. Minor vignetting in the rest of the image is also fixed by the lens profile, but the major vignetting you are seeing in the corners is simply discarded information in the final image. The strange thing is that you are getting the vignetting at all. That is mechanical vignetting caused by the lens hood (or a filter) intruding into the image path. I am surprised it’s there. It shouldn’t be. Leica shouldn’t have cut it that close in the design even though the extreme corners are going to get discarded. I don’t see that sort of mechanical vignetting in my Lightroom previews. Not sure why your camera appears different. I would have guessed that the hood was not quite all the way on—that a slight rotation of the rectangular hood was allowing it to intrude. But, you have said the hood is all the way screwed on. I’d encourage you to double check. It needs to be not just tight, but screwed on until it hits a stop at the end of the threads. Link to post Share on other sites More sharing options...
microview Posted September 20, 2020 Share #27 Posted September 20, 2020 Advertisement (gone after registration) On 6/15/2020 at 4:12 AM, bcorton said: If you need a post-processing app, you can also check out Affinity Photo, Irridient Developer, or ON1. They are powerful, inexpensive, and non-subscription (I.e., buy once) options. Recommend Irident Developer: compatible with latest Mac OS and inexpensive. Free upgrades for several years. Not quite as flexible as LR, where I am happy with LR5 which I also use and I dislike subscription options. Link to post Share on other sites More sharing options...
Miltz Posted September 24, 2020 Share #28 Posted September 24, 2020 You're seeing the lens distortion without corrections, that's all. It's completely normal. Use something like Lightroom or Photoshop. You won't have that issue. Link to post Share on other sites More sharing options...
