beewee Posted March 17, 2022 Share #21  Posted March 17, 2022 Advertisement (gone after registration) 52 minutes ago, leicamr said: In the attached image of a three cam R lens mount, I believe that Cam number 1 (at the top of the lens) makes contact with the adapter electrical contact strip. I have just compared the adapter pins with those on my R9. The pins in the R9 are notably of smaller diameter, hence is not an issue when a 3 cam lens is mounted on an R body. The adapter compatibility chart needs to indicate that 3 CAM lens will touch the contacts. I cannot determine if damage will caused if the lens is stopped down beyond f5.6. It would be good to know. Mark  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I would have expected if this is an issue that it would have been identified on R bodies as well. 1 Link to post Share on other sites More sharing options...
Advertisement Posted March 17, 2022 Posted March 17, 2022 Hi beewee, Take a look here Using R lenses on the SL2. I'm sure you'll find what you were looking for!
