Hello,
This morning everything ok, but after a few photos purple haze and later the dots... The dots is maybe the corrosion, but what happend with this sensor?
What can Leica do? This is a second hand M9, so no warranty...is there a possibility for an upgrade?
Is this happening with every frame, or just one or a few? This may not help, but you should try different cards and batteries just to make sure it's not something simple. If it's happening with every frame and with different cards, I would think that you have a sensor fault that can only be fixed by Leica.
Ok, thanks for the replies.
Tried another battery and sd-card. The first two shots were ok. But more and more the purple haze appears in the centre and 5 frames later everything purple...
I've contacted my dealer...
Edited by Filip Meutermans
