otto.f Posted March 22, 2020 Share #21 Posted March 22, 2020 (edited) Advertisement (gone after registration) On 3/19/2020 at 9:15 PM, pridbor said: new Dx sensor If you look through the viewfinder at the moment you put your M7 on, you will see the ASA value coming up. I don’t use the dx-code btw because some new films don’t have a code and if I set it manual I can always see what’s in it. Same for M4, which even has a choice for slide, B&W and color Edited March 22, 2020 by otto.f 1 Link to post Share on other sites More sharing options...
Advertisement Posted March 22, 2020 Posted March 22, 2020 Hi otto.f, Take a look here I forgot what Film is in my camera, how do you keep track?. I'm sure you'll find what you were looking for!
oldwino Posted March 23, 2020 Share #22 Posted March 23, 2020 I only use one film. 1 Link to post Share on other sites More sharing options...
jmahto Posted March 27, 2020 Share #23 Posted March 27, 2020 On 3/23/2020 at 8:36 AM, oldwino said: I only use one film. What do you do once you reach the end of that film? 2 Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted March 27, 2020 Share #24 Posted March 27, 2020 When I had M2s they had a dial on the back door that you could set color/b&w and film speed, worked well. My M3 doesn't have that, right now I am using TMax 100 almost exclusively. But I keep my films to a minimum, I also used to use colored dots Green for ISO 400 b&w, blue for ektachrome, red for Kodachrome, yellow for slow b&w films, but that was on the plastic film containers in my bag, not on the camera, could go that way. 1 Link to post Share on other sites More sharing options...
sblitz Posted March 27, 2020 Share #25 Posted March 27, 2020 dial on the back door, shove a bit of the film box where the flash or meter would go .... 1 Link to post Share on other sites More sharing options...
abrewer Posted April 4, 2020 Share #26 Posted April 4, 2020 On 3/19/2020 at 4:48 PM, Ouroboros said: I tear a bit off the box, enough to identify the film and push it into the hot shoe. Yup, one of the first tricks I learned about my MP Link to post Share on other sites More sharing options...
Ko.Fe. Posted April 4, 2020 Share #27 Posted April 4, 2020 Advertisement (gone after registration) On 3/20/2020 at 6:45 AM, wattsy said: I think the OP's camera is an M7 so the question of film speed shouldn't be a problem, unless the OP rolls his own and is in the habit of using different film types frequently. mnutzer has the right answer – just partially rewind the film and have a look at it. M7 has two modes. Read the code or set the ISO manually. Not sure what OP problem was. Forgot to dial in right ISO? Then keep on shooting, read camera ISO, compare to film ISO. Push or pull. And why rewind partially? Take a note how many frames are exposed. Rewind until it you feel it leaves take in. Open the thing, look at film. Get it back to camera. Keep lens cap on. Advance/release to couple of more frames it was on before rewind. Link to post Share on other sites More sharing options...
adan Posted April 4, 2020 Share #28 Posted April 4, 2020 (edited) Surprisingly, someone is still making these: https://www.shapeways.com/product/F64JCWH2E/memo-holder-for-film-camera The medium or small size may fit on a Leica-M back, beside the meter ISO dial. (Warning - do not use these on M4-2/P cameras - they can rip the write-on plastic note circle right off the camera when removed!!) When I used M4-2/Ps, I used to find the sticky 1.9 cm colored dots mentioned above, in office supply stores - and stick them in the center of those cameras' "write-on" reminder patches (same back location as meter ISO dials today). https://www.staples.com/Avery-Round-3-4-Diameter-Print-and-Write-Color-Coding-Labels-Assorted-Colors-1-008-Pack-13958-5472/product_297705?cid=PS:GooglePLAs:297705&ci_src=17588969&ci_sku=297705&KPID=297705&gclid=EAIaIQobChMIwLzwzeDN6AIVR_7jBx1efwRLEAQYBCABEgKfjvD_BwE Color-coded according to the manufacturers' own film box colors: green for Tri-X/HP-5, purple for Plus-X, brown or orange for Panatomic-X/Pan-F, red for Kodachrome, blue for Ektachrome (if needs be, light blue for ISO 64/100, navy blue for ISO 400), Kodak yellow for any color neg film (rarely used). Once I moved to M6s, I just put the sticky-dots on either the top or bottom plate. Sometimes overlapping the bottom opening-key as a reminder "FILM IN CAMERA - DO NOT OPEN!" ____________________________ If one believes in Das Wesentliche, one avoids the problem with the mantra "One camera, one lens, one film." Edited April 4, 2020 by adan 1 Link to post Share on other sites More sharing options...
Ouroboros Posted April 4, 2020 Share #29 Posted April 4, 2020 6 hours ago, Ko.Fe. said: M7 has two modes. Read the code or set the ISO manually. Not sure what OP problem was. Forgot to dial in right ISO? The ‘problem’ might also be that he has forgotten whether he has colour or black and white film in his camera! Link to post Share on other sites More sharing options...
MarkP Posted April 4, 2020 Share #30 Posted April 4, 2020 On 3/20/2020 at 7:48 AM, Ouroboros said: I tear a bit off the box, enough to identify the film and push it into the hot shoe. That's what I do. Link to post Share on other sites More sharing options...
gbealnz Posted April 4, 2020 Share #31 Posted April 4, 2020 14 hours ago, MarkP said: That's what I do. Me too 1 Link to post Share on other sites More sharing options...
