ansch Posted April 12, 2024 Share #21 Posted April 12, 2024 Advertisement (gone after registration) So I recently acquired a M10-M and experienced the same issue. Panic at first but worked out that it is the shutter button surround coming loose. I've previously taken the shutter button apart on my M9 so I'm not afraid to poke around. The M10-M shutter button comes out in one assembly. You can see that if the surround is loose and unscrewed a bit, the shutter pin will not reach the shutter button in the camera. Interestingly there are three metal shims between the shutter button assembly and the body. It's required for the on off switch to work but if you remove one, it seems to make the shutter button sit higher. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/306603-m10p-shutter-release-button-fault/?do=findComment&comment=5182751'>More sharing options...
Advertisement Posted April 12, 2024 Posted April 12, 2024 Hi ansch, Take a look here M10P shutter release button fault. I'm sure you'll find what you were looking for!
AceVentura1986 Posted April 12, 2024 Share #22 Posted April 12, 2024 On 1/5/2023 at 1:34 PM, kevinjoe said: See this pic for an explanation. It's just a part that is threaded on and sits on top of on / off switch. If it loosens (i.e. turns counter clockwise), it sits higher and prevents you from fully engaging the shutter button. You have to grab it and turn clockwise (without grabbing the on/off switch). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Thanks. I got an M10M in December and will keep thin in mind just in case. 1 Link to post Share on other sites More sharing options...
ansch Posted April 16, 2024 Share #23 Posted April 16, 2024 On 4/12/2024 at 4:03 PM, ansch said: So I recently acquired a M10-M and experienced the same issue. Panic at first but worked out that it is the shutter button surround coming loose. I've previously taken the shutter button apart on my M9 so I'm not afraid to poke around. The M10-M shutter button comes out in one assembly. You can see that if the surround is loose and unscrewed a bit, the shutter pin will not reach the shutter button in the camera. Interestingly there are three metal shims between the shutter button assembly and the body. It's required for the on off switch to work but if you remove one, it seems to make the shutter button sit higher. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! On further investigation, you can't remove any of the shims as it makes the on/off switch harder to move. Instead, you can turn the silver disc on the shutter assembly counter-clockwise to loosen it a bit and it will make the shutter button higher up. Link to post Share on other sites More sharing options...
Alex masselot Posted July 22, 2024 Share #24 Posted July 22, 2024 On 6/11/2020 at 6:17 PM, Twasi said: I’ve just discovered that sometimes the shutter housing can come unscrewed and you need to screw it back down or the shutter won’t work Thank you one thousand times for the tip. You saved my day. Link to post Share on other sites More sharing options...
