I doubt that the L-Mount alliance members will sell extension tubes, but we may see some from third-party suppliers.
The problem is that you lose a lot of quality by using a modern lens outside of its designed focusing range, and that would be painfully obvious with 47MP files. They would much rather sell you a macro lens (Leica has one for APS-C, Sigma has one for full frame, and the Panasonic kit zoom goes to 1:2).
That being said, you can use extension tubes and bellows on adapted lenses if you want. That opens-up a whole world of enlarger lenses and macro/micro lenses.
  • 1 month later...
The old Elmar 135 (1960) is actually slightly better for close up than the newer much (10x) more expensive M Tele-Elmar 135.
Of modern equipment the irix 150mm is good and goes to 1:1 .
I would still like to see closeup rings for L-mount. And an extender (1.7x) for the 90-280 and the 50, 75 and 90 Summicron. They are Apo lenses, so they can lose a bit of quality without problem.
The Apo M 50 also works very well with extension tubes, it’s just a bit too expensive.
Edited by caissa
  • 1 year later...
  • 1 month later...
On 1/9/2022 at 11:16 AM, Eros Penatti said:
They  finally arrived :
https://www.bhphotovideo.com/c/product/1677832-REG/viltrox_dg_l_automatic_extension_tube_for.html
I hope to be able use them with the SL2S and the Sigma 105 Macro Art.
In theory:
Attaching the 12mm tube to the Sigma 105mm should enable magnification of 1.11 : 1 compared to native magnification 1:1
Attaching the 24mm tube should enable magnification 1.22 : 1
Attaching both tubes ie 36mm should enable magnification 1.34 : 1
To obtain in excess of 1.5: 1 magnification will require  another 24mm length i.e 60mm which should enable 1.58 : 1
I have also ordered the Viltrox tubes but will be using them with a shorter focal length L mount lens which will enable greater magnification than with the 105mm lens.
Tubes are en-route from China and expected to arrive mid-March
dunk
Edited by dkCambridgeshire
  • 1 month later...
