Jonathan Levin Posted November 8, 2019 Share #1  Posted November 8, 2019 (edited) Advertisement (gone after registration) Hi all. Just to confirm, can one use a Nikkor F (AF) mount on the SL2??? Is there an adapter needed to make all that work? Cost? I have a bunch of old 35mm neg and transparencies I will be copying using the 60mm Nikkor Macro paired with the ES-2 adapter. Would this combo work? Using F mount lens, do you still get full sensor or is that cropped in some way. Thank you. Jonathan Edited November 8, 2019 by Jonathan Levin Link to post Share on other sites More sharing options...
Advertisement Posted November 8, 2019 Posted November 8, 2019 Hi Jonathan Levin, Take a look here Using Nikkor Macro lens on SL2?. I'm sure you'll find what you were looking for!
AZN Posted November 8, 2019 Share #2 Â Posted November 8, 2019 I have the Novoflex adapter with built in aperture control https://www.bhphotovideo.com/c/product/1103373-REG/novoflex_let_nik_lens_mount_adapter.html Copying film can be a bit tricky, but once you get over the learning curve it is much superior to scanning (for 35mm film). 1 Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 8, 2019 Author Share #3 Â Posted November 8, 2019 Thanks AZN. That looks like it would work, although you lose some functions. I found this: https://www.bhphotovideo.com/c/product/1318290-REG/novoflex_sl_nik_nikon_af_lens_adapter.html but at $829.00US seems a bit out of reach. The one you have is $234.00US. Link to post Share on other sites More sharing options...
250swb Posted November 9, 2019 Share #4 Â Posted November 9, 2019 13 hours ago, Jonathan Levin said: I will be copying using the 60mm Nikkor Macro paired with the ES-2 adapter. If your lens has a manual aperture ring you don't need an adapter with a built in aperture control, all you need is the cheapest spacer type of adapter, anything Chinese will do. Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 9, 2019 Author Share #5 Â Posted November 9, 2019 Thanks for the answers. The 60mm Macro ED lens I was looking at does not have an aperture ring. I may have to rethink this one. Link to post Share on other sites More sharing options...
Jeffry Abt Posted November 9, 2019 Share #6  Posted November 9, 2019 (edited) This lens "AF Micro Nikkor 60mm 1:2.8 D" will work well the "Novoflex Nikon F Lens to Leica SL/T Camera Body Lens Adapter".  The Nikkor lens is now "retired" but you may be able to find it use. I use it to digitize slides with a Nikon adapter "ES-1". It all works well together. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  that fits in front of the lens. Edited November 9, 2019 by Jeffry Abt Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  that fits in front of the lens. ' data-webShareUrl='https://www.l-camera-forum.com/topic/303299-using-nikkor-macro-lens-on-sl2/?do=findComment&comment=3851332'>More sharing options...
michali Posted November 9, 2019 Share #7  Posted November 9, 2019 Advertisement (gone after registration) I've been digitising my slides using a slide duplicator from my film days. We used these to duplicate slides by photographing them, the duplicator also has a manual zoom function for cropping purposes.  It has an M42-T mount which I use with an M42-SL mount adapter on the SL. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!   1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!   ' data-webShareUrl='https://www.l-camera-forum.com/topic/303299-using-nikkor-macro-lens-on-sl2/?do=findComment&comment=3851349'>More sharing options...
Jeffry Abt Posted November 9, 2019 Share #8  Posted November 9, 2019  The "Novoflex Nikon F Lens to Leica SL/T Camera Body Lens Adapter" works well with any Nikkor lens that has an aperture ring. Here with a old 85mm 1:14D lens. But everything is manual, so no autofocus.  I'm looking forward to using the 85mm 1:14D with the New SL2. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/303299-using-nikkor-macro-lens-on-sl2/?do=findComment&comment=3851355'>More sharing options...
Jonathan Levin Posted January 18, 2022 Author Share #9  Posted January 18, 2022 Hi All.  Since I started this thread over a year ago, things have changed. A while back I traded my Nikon AF Micro-NIKKOR 60mm f/2.8D Lens (the lens that HAS the Aperture ring) for the Nikon AF-S Micro NIKKOR 60mm f/2.8G ED Lens (current model, but no aperture ring) Long story. Again, I'll be using this, if possible with the SL2(s) to copy slides with the ES-2 adapter like I did with the Nikon D850. Since there is no aperture ring on this lens, can it be used with this Novoflex F-L adapter?  https://www.bhphotovideo.com/c/product/1103373-REG/novoflex_let_nik_lens_mount_adapter.html/compatibility Compatibly states it SHOULD work, but how do you adjust f/stops? I have tried reaching Novoflex but have not heard back. I was curious if anyone id using this exact setup? Thanks. Jonathan Link to post Share on other sites More sharing options...
TealWayFilms Posted January 18, 2022 Share #10 Â Posted January 18, 2022 I chose a different path to scan with my SL and SL2-S Â Link to post Share on other sites More sharing options...
caissa Posted January 23, 2022 Share #11 Â Posted January 23, 2022 (edited) I use some D lenses adapted. Also the macro lenses (60, 105, 200). I use the D lenses because it is easy to focus manually. And there are special lenses like the micro 70-180. I would like to see a close focus adapter for L, and maybe extenders. (Ok, the Sigma extenders can be used with the sigma macro). Unfortunately nobody has solved the problem of using D lenses with AF, not even Nikon for their mirrorless cameras. There are millions of lenses, so I hope that sooner or later someone offers it. Edited January 23, 2022 by caissa 1 Link to post Share on other sites More sharing options...
NickT Posted January 28, 2022 Share #12  Posted January 28, 2022 Since there is no aperture ring on this lens, can it be used with this Novoflex F-L adapter? You turn the blue ring that you can see in Jeffry Abt's photo. The F stops are not marked so you just have to guess. I have used this system and it works OK, but I found the Laowa 100mm macro L mount lens to produce better results https://www.cameralabs.com/laowa-100mm-f2-8-2x-macro-apo-review/ Link to post Share on other sites More sharing options...
Jonathan Levin Posted January 28, 2022 Author Share #13  Posted January 28, 2022 (edited) NickT, so its the blue ring thing. Thank you for clearing that up. once focus is achieved wide open, turn the ring to desired “stop”. Sounds like placing some sort of mark on lens/ring to acheive consistent results when doing copy work should work. again thanks! jonathan Edited January 28, 2022 by Jonathan Levin Link to post Share on other sites More sharing options...
