Mikael E. Posted October 4, 2019 Share #1 Posted October 4, 2019 Advertisement (gone after registration) Dear Leica-Enthusiasts, I have been shooting with the Leica CL since a few months now and always use M lenses with the Leica and Novoflex adapters. However, over these last months I have noticed that lens-adapter-camera combination is not completely rigid. I can now slightly rotate the mount back and forth. It does not seem to affect the IQ but I am worried that it might loosen even more. Has anyone had similar experiences? I will probably just send it in to Wetzlar... Mika Link to post Share on other sites More sharing options...
Advertisement Posted October 4, 2019 Posted October 4, 2019 Hi Mikael E., Take a look here L bayonet wobbles - normal?. I'm sure you'll find what you were looking for!
jaapv Posted October 4, 2019 Share #2 Posted October 4, 2019 Slight play in rotation is normal and acceptable. A lateral movement or lens droop not. Link to post Share on other sites More sharing options...
wda Posted October 4, 2019 Share #3 Posted October 4, 2019 If it troubles you, I would suspect the adapter, not the camera body. If so, Novoflex should be able to advise you, not Leica. Link to post Share on other sites More sharing options...
Linus84 Posted October 4, 2019 Share #4 Posted October 4, 2019 Same issue here with all my L-lenses and the Leica L to M adapter. A fraction of a mm play in the “torque” direction when lenses are mounted. Seems to be normal? Link to post Share on other sites More sharing options...
Mikael E. Posted October 4, 2019 Author Share #5 Posted October 4, 2019 Thanks for your comments. I had a quick look to the Leica Shop in Vienna and they confirmed that the LM-Adapter has some play along the torque direction. It is less evident with small lenses, they said. I have my rather heavy Voigtländer 50/1.2 on there, so it is more pronounced. I also noticed that there is more play with the Novoflex adapter compared to the native Leica LM adapter. Seems to be normal then... 1 Link to post Share on other sites More sharing options...
