Alan Clarke Posted August 17, 2019 Share #1 Posted August 17, 2019 Advertisement (gone after registration) Leica Dlux 7 Camera freezes especially after charging. Anyone else having this problem. I have found that taking battery out and reinstall it gets it working again. Just a little concerned as camera only a Month old. Link to post Share on other sites More sharing options...
Advertisement Posted August 17, 2019 Posted August 17, 2019 Hi Alan Clarke, Take a look here Leica Dlux 7 Camera freezes . I'm sure you'll find what you were looking for!
cubeedoo Posted August 17, 2019 Share #2 Posted August 17, 2019 Same for me, happens mostly when connected to WiFi. As long as you do not access pictures everything should be fine. I guess it's a firmware issue, but I did not find an update for 1.1 yet. Link to post Share on other sites More sharing options...
bdickers Posted August 18, 2019 Share #3 Posted August 18, 2019 I have also had this happen. Also, I cannot select the AE\AF function from the menu system regardless or the mode the camera is in. 1 Link to post Share on other sites More sharing options...
JHPINLA Posted April 6, 2020 Share #4 Posted April 6, 2020 I also have this problem on the D-Lux 7. The camera is 6 months old and it has happened twice in the last month. the camera freezes and cannot be turned off in the normal way, the controls have no effect and the lens is stuck out. Both times, the only way to fix this was to remove the battery. Has anyone found a fix? Is there a software fix coming? Link to post Share on other sites More sharing options...
lykaman Posted April 6, 2020 Share #5 Posted April 6, 2020 Hi All, I use an external Battery Charger, use FOTOS and have no Freezing Issues (yet) Camera is 2 months old.. In regards to Settings, try aMenu Reset.. Use higher EVF refresh rate... L Link to post Share on other sites More sharing options...
Othon A. Leon Posted January 2, 2022 Share #6 Posted January 2, 2022 Hello! It happened twice to my brand new DL7 today! No apparent reason… very annoying! Link to post Share on other sites More sharing options...
TBPhoto35 Posted January 12, 2022 Share #7 Posted January 12, 2022 Advertisement (gone after registration) Thanks for this post. Was considering a D-Lux 7 for travel, but now holding off... Link to post Share on other sites More sharing options...
cubeedoo Posted January 12, 2022 Share #8 Posted January 12, 2022 vor 1 Stunde schrieb TBPhoto35: Thanks for this post. Was considering a D-Lux 7 for travel, but now holding off... At least for me it's running without any issues since the last firmware update. Link to post Share on other sites More sharing options...
Keith (M) Posted January 13, 2022 Share #9 Posted January 13, 2022 Bought mine in April 2020 and it is my 'go to' pocket camera when out & about in town and countryside and it has always performed flawlessly. 1 1 Link to post Share on other sites More sharing options...
dgstng Posted October 13, 2022 Share #10 Posted October 13, 2022 Hi there, i've bought my d-Lux 7 used and unfortunately I've realized that it was at whopping 15000 shots!! I feel like i'm fooled. I also had the same freezing issue today and had to remove the battery. I thought that it is related with gps information pass. Don't think that it is related with Leica FOTOS app. Also a better SD card might help. Because except that one freeze, it is incredibly responsive and fast. Link to post Share on other sites More sharing options...
jaapv Posted October 15, 2022 Share #11 Posted October 15, 2022 15000 is not that much… 1 Link to post Share on other sites More sharing options...
cubeedoo Posted October 15, 2022 Share #12 Posted October 15, 2022 Am 13.10.2022 um 22:39 schrieb dgstng: Hi there, i've bought my d-Lux 7 used and unfortunately I've realized that it was at whopping 15000 shots!! I feel like i'm fooled. I also had the same freezing issue today and had to remove the battery. I thought that it is related with gps information pass. Don't think that it is related with Leica FOTOS app. Also a better SD card might help. Because except that one freeze, it is incredibly responsive and fast. A few months later I can say it's perfectly reliable. No issues at all. And with some experience from other cams I'd feel happy with 15k, that's fine. Link to post Share on other sites More sharing options...
RyanS Posted March 25, 2023 Share #13 Posted March 25, 2023 Mine is 2 years old and so far these are the faults - 1 Metering is off by at least 2 stops. 2 Auto focus is very jumpy and I mostly have to go manual. 3 Zoom jams and will not extend. I have to pull it out manually. 4 Zoom lever does not work 50% of the time. I end uo using the ring on the lens. 5 crashes so often ive got used to dropping the battery witout a seconds thought. 6 Dirt on the inside of the lens that shows up on all wide angle shots. From factory! 7 Batterry door jams due to case twisting. think thats it off the top my head. Link to post Share on other sites More sharing options...
jaapv Posted March 25, 2023 Share #14 Posted March 25, 2023 If the dirt is there from new why did you accept the camera? it sounds like you have a lemon. Normally Panasonics are pretty solid cameras. Any camera with such complaints would find itself returned immediately in my hands. Link to post Share on other sites More sharing options...
Pankaj Posted March 25, 2023 Share #15 Posted March 25, 2023 7 hours ago, RyanS said: Mine is 2 years old and so far these are the faults - 1 Metering is off by at least 2 stops. 2 Auto focus is very jumpy and I mostly have to go manual. 3 Zoom jams and will not extend. I have to pull it out manually. 4 Zoom lever does not work 50% of the time. I end uo using the ring on the lens. 5 crashes so often ive got used to dropping the battery witout a seconds thought. 6 Dirt on the inside of the lens that shows up on all wide angle shots. From factory! 7 Batterry door jams due to case twisting. think thats it off the top my head. So many mechanical problems - looks like someone dropped it from a height and then quietly put it back on sales shelf. Send it authorised dealer for repair. Link to post Share on other sites More sharing options...
70racing Posted March 26, 2023 Share #16 Posted March 26, 2023 How do I determine number of shutter activations on my DL7? Thanks, Bob Link to post Share on other sites More sharing options...
cubeedoo Posted March 26, 2023 Share #17 Posted March 26, 2023 vor einer Stunde schrieb 70racing: How do I determine number of shutter activations on my DL7? Thanks, Bob You can't (or at least I never found out) but the file name can be a hint. Link to post Share on other sites More sharing options...
Krusty Posted April 1, 2024 Share #18 Posted April 1, 2024 Am 17.8.2019 um 10:14 schrieb Alan Clarke: Leica Dlux 7 Camera freezes especially after charging. Anyone else having this problem. I have found that taking battery out and reinstall it gets it working again. Just a little concerned as camera only a Month old. My DLUX Typ 109 freezes EVERY TIME when I press the Play Button or when I enter the play menu. i always have to remove the battery. unfortunately there is no firmware update so 1.0 is still the current version Link to post Share on other sites More sharing options...
