kepstein Posted August 2, 2019 Share #1 Posted August 2, 2019 Advertisement (gone after registration) My shutter release feels notchy, and is sometimes hard to depress. Is this a common issue? Thanks, Ken Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2019 Posted August 2, 2019 Hi kepstein, Take a look here M10 rough shutter release . I'm sure you'll find what you were looking for!
pico Posted August 2, 2019 Share #2 Posted August 2, 2019 Are you using a soft-release? Link to post Share on other sites More sharing options...
kepstein Posted August 2, 2019 Author Share #3 Posted August 2, 2019 No soft release. Link to post Share on other sites More sharing options...
jdlaing Posted August 2, 2019 Share #4 Posted August 2, 2019 Sounds like maybe a piece of grit in there. Try a rocket blower. Link to post Share on other sites More sharing options...
kepstein Posted August 3, 2019 Author Share #5 Posted August 3, 2019 13 hours ago, jdlaing said: Sounds like maybe a piece of grit in there. Try a rocket blower. How do I do this, do I unscrew anything? thanks, ken Link to post Share on other sites More sharing options...
jdlaing Posted August 3, 2019 Share #6 Posted August 3, 2019 Just blow around the shutter button and see if gets better. I wouldn’t unscrew anything. Link to post Share on other sites More sharing options...
albertknappmd Posted August 6, 2019 Share #7 Posted August 6, 2019 Advertisement (gone after registration) If not... send it back... Nothing more you can do.. Albert Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/299883-m10-rough-shutter-release/?do=findComment&comment=3792583'>More sharing options...
Reciprocity Posted August 13, 2019 Share #8 Posted August 13, 2019 Mine is the same and was even the same after coming back from service via Leica NJ. I even find it to be notchy using a soft release. Not the best shutter release feel I have experienced in a Leica body to be sure. Link to post Share on other sites More sharing options...
kepstein Posted August 13, 2019 Author Share #9 Posted August 13, 2019 3 minutes ago, Reciprocity said: Mine is the same and was even the same after coming back from service via Leica NJ. I even find it to be notchy using a soft release. Not the best shutter release feel I have experienced in a Leica body to be sure. I used hand blower and then added my soft release, and it feels a little better. I maybe wishful thinking. The shutter is not as smooth as my M6 TTL, M8, or M240. Link to post Share on other sites More sharing options...
Cliff S Posted August 14, 2019 Share #10 Posted August 14, 2019 i used alcohol on a swab and rubbed it on the edges and my shutter came back to life Link to post Share on other sites More sharing options...
kepstein Posted June 9, 2020 Author Share #11 Posted June 9, 2020 I will try this too, but mine causes me to select a faster shutter in order to avoid shake. The shutter is not nearly as smooth as my M6TTL, M8, or M240. On 8/14/2019 at 11:59 AM, Cliff S said: i used alcohol on a swab and rubbed it on the edges and my shutter came back to life Link to post Share on other sites More sharing options...
kepstein Posted November 17, 2020 Author Share #12 Posted November 17, 2020 Any recent solutions to the rough shutter release? Thanks, Ken Link to post Share on other sites More sharing options...
kepstein Posted February 19, 2021 Author Share #13 Posted February 19, 2021 On 11/17/2020 at 6:42 PM, kepstein said: Any recent solutions to the rough shutter release? Thanks, Ken Link to post Share on other sites More sharing options...
Doc748 Posted February 22, 2021 Share #14 Posted February 22, 2021 keptstein, my recently acquired M10-R developed this problem as well. It wouldn't fire unless you exert enourmous force on shutter. Josh, at Leica Store Miami, asked me to bring it to the store to take a look at it. Bottom line, mine had a loose part on the shutter (I am not a technical person on this topic). He tightened it and now it works like a charm. You may want to contact Josh at the store and ask him to walk you through this process. It may be the same problem as yours. Javier Link to post Share on other sites More sharing options...
kepstein Posted February 23, 2021 Author Share #15 Posted February 23, 2021 On 2/22/2021 at 1:24 PM, Doc748 said: keptstein, my recently acquired M10-R developed this problem as well. It wouldn't fire unless you exert enourmous force on shutter. Josh, at Leica Store Miami, asked me to bring it to the store to take a look at it. Bottom line, mine had a loose part on the shutter (I am not a technical person on this topic). He tightened it and now it works like a charm. You may want to contact Josh at the store and ask him to walk you through this process. It may be the same problem as yours. Javier Thanks for the advice, I will give Josh a call. Link to post Share on other sites More sharing options...
wrussell Posted November 30, 2021 Share #16 Posted November 30, 2021 Did you ever get this resolved? Can you DIY this or does it really need to be taken in? Link to post Share on other sites More sharing options...
kepstein Posted November 30, 2021 Author Share #17 Posted November 30, 2021 5 hours ago, wrussell said: Did you ever get this resolved? Can you DIY this or does it really need to be taken in? No, and it continues to limit my use and enjoyment. I would love a DIY solution that works. Link to post Share on other sites More sharing options...
wrussell Posted November 30, 2021 Share #18 Posted November 30, 2021 2 hours ago, kepstein said: No, and it continues to limit my use and enjoyment. I would love a DIY solution that works. Well, my m10-R is about 12 hours old and already has this issue. Working to figure out solution with the boutique. In basically any other product I’d just return/exchange for a new one but body language on the forum here makes it seem like this is something we’re supposed to eat and have them tear apart a brand new camera as part of a warranty claim… Link to post Share on other sites More sharing options...
wrussell Posted December 1, 2021 Share #19 Posted December 1, 2021 18 hours ago, kepstein said: No, and it continues to limit my use and enjoyment. I would love a DIY solution that works. As an update here, they replaced my camera entirely. New one seems to work like a charm. A few other forum users had the same issue apparently but the solution is opaque - sounds like they went in for varying levels of off-site service, but ultimately resolved the issues. Best of luck. Link to post Share on other sites More sharing options...
