tom0511 Posted August 2, 2019 Share #41 Posted August 2, 2019 Advertisement (gone after registration) I think the system would really benefit a lot from a smaller AF point. The lenses render so good.... 1 Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2019 Posted August 2, 2019 Hi tom0511, Take a look here S100mm 2.0 verses HC80 1.9 . I'm sure you'll find what you were looking for!
Stuart Richardson Posted August 2, 2019 Share #42 Posted August 2, 2019 Agreed, a more precise central AF point would allow people to be more confident in what the AF point is actually choosing as the point of focus. I expect that by improving that alone, a large number of the AF failures would go away. I try to compensate for this as much as possible by finding a flat surface that encompasses the entire AF circle, but it is not always possible or practical. Certainly it is too large to accurately pick out an eye in an environmental portrait, for example. If the AF point was a smaller circle, say a bit smaller than the cross, I think it would be more consistent. Link to post Share on other sites More sharing options...
Vieri Posted August 5, 2019 Share #43 Posted August 5, 2019 On 7/4/2019 at 3:19 AM, NW67 said: I thought about getting the XCD 120 macro but I hear it hunts all the time............do the HC lenses fit the X1D II via an adapter and retain AF? Neil, I think you'd be better served by the 90mm + 135mm combo for portraits - the first for wider ones, the latter for headshots & closer compositions. Yes, HC lenses do work with the X1D retaining autofocus, provided lend FW is 18.0.0.0 or later, see here: https://www.hasselblad.com/x-system-lenses/xh-lens-adapter/ Hope this helps! Best regards, Vieri Link to post Share on other sites More sharing options...
