cbretteville Posted June 27, 2019 Share #1 Posted June 27, 2019 Advertisement (gone after registration) The Panasonic pages for FW updates has a link to what should be a description of the update procedure from a Leica camera body. This link takes you to the L-Mount landing page. I suspect the procedure is to copy the file to a memory card and turne the camera on after having inserted a fresh battery, but I may be wrong. Does anyone have a description or a link to it? Thanks, Carl Link to post Share on other sites More sharing options...
Advertisement Posted June 27, 2019 Posted June 27, 2019 Hi cbretteville, Take a look here Lumix lens FW update prodecdure from a Leica body?. I'm sure you'll find what you were looking for!
CharlesL Posted June 28, 2019 Share #2 Posted June 28, 2019 That is the usual procedure from the several manufacturers whose updates I have done. Don't see any risk of harm for a lens update. Link to post Share on other sites More sharing options...
Leicaiste Posted August 17, 2019 Share #3 Posted August 17, 2019 (edited) On 6/27/2019 at 11:03 PM, cbretteville said: I suspect the procedure is to copy the file to a memory card and turn the camera on after having inserted a fresh battery, but I may be wrong. You are right. I have just upgraded the Lumix 24-105 from the Leica SL by following the instruction for the camera firmware upgrade. The Lumix lens firmware add a line in the "Camera information" menu on the SL. Quite easy. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 17, 2019 by Leicaiste 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/298723-lumix-lens-fw-update-prodecdure-from-a-leica-body/?do=findComment&comment=3799557'>More sharing options...
rfunnell Posted August 17, 2019 Share #4 Posted August 17, 2019 Does anyone know where the firmware for the Lumix 24-105 can be found ? Or is it included in the Leica SL latest firmware . Thanks Link to post Share on other sites More sharing options...
erudolph Posted August 17, 2019 Share #5 Posted August 17, 2019 Lumix S 24-105 and S 70-200 firmware can be downloaded here FWIW, I couldn't find the change log on the above website, but I did find one on a blogger's website. The changes noted for the 24-105 are "Improved the performance of O.I.S.(Optical Image Stabilizer)." For the 70-200, the change is the same, plus FW update 1.1 adds support for the two new teleconverters. Updating on a CL, the procedure is the same as for updating camera FW, as previous posters have said. There is an additional menu item under Camera Information for updating the lens. Link to post Share on other sites More sharing options...
Ivar B Posted October 19, 2019 Share #6 Posted October 19, 2019 On 8/17/2019 at 3:46 PM, rfunnell said: Does anyone know where the firmware for the Lumix 24-105 can be found ? Or is it included in the Leica SL latest firmware . Thanks In case you have not found it, here it is:https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/index4.html# I just downloaded a firmware update for the 70-200 and this worked perfectly. There is also an update for the 24-105. 1 Link to post Share on other sites More sharing options...
jrp Posted October 19, 2019 Share #7 Posted October 19, 2019 Advertisement (gone after registration) The Sigma 45mm f2.8 also has a firmware update (to better report power consumption to SL, eg). Remember to switch off the Bluetooth to enable firmware updating on the Panasonic S1/R cameras. 1 Link to post Share on other sites More sharing options...
