lpeeples Posted May 26, 2019 Share #1 Posted May 26, 2019 (edited) Advertisement (gone after registration) Question and a comment... does the Q2 and Q use the same lens cap? I'm disappointed the Q2 lens cap loosens up and it's fallen off a couple times. I can order another (most sites are the for the Q), and I want to make sure it fits. With that said, the KUVRD rubber lens cap fits perfect on it, over the hood and covers the bump where you switch btn autofocus and manual. I use it on my Nocti with a variable ND and tried it on the Q2. Not to tight or loose, just right. The new lens cap is going in the box... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited May 26, 2019 by lpeeples Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/297672-q2-lens-cap/?do=findComment&comment=3748021'>More sharing options...
Advertisement Posted May 26, 2019 Posted May 26, 2019 Hi lpeeples, Take a look here Q2 Lens Cap . I'm sure you'll find what you were looking for!
Donzo98 Posted May 26, 2019 Share #2 Posted May 26, 2019 I bought a 49mm cap from Breakthrough Photography. Link to post Share on other sites More sharing options...
Leica Guy Posted May 26, 2019 Share #3 Posted May 26, 2019 I left the cap in the box. Never use it. The hood and a UV filter are great. 4 Link to post Share on other sites More sharing options...
Dominique1952 Posted May 26, 2019 Share #4 Posted May 26, 2019 2 hours ago, lpeeples said: Question and a comment... does the Q2 and Q use the same lens cap? I'm disappointed the Q2 lens cap loosens up and it's fallen off a couple times. I can order another (most sites are the for the Q), and I want to make sure it fits. With that said, the KUVRD rubber lens cap fits perfect on it, over the hood and covers the bump where you switch btn autofocus and manual. I use it on my Nocti with a variable ND and tried it on the Q2. Not to tight or loose, just right. The new lens cap is going in the box... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I'm not the only one who has bought a cheap plastic 49 mm cap. The original cap on the Q is not convenient, it's falling down all the time. Link to post Share on other sites More sharing options...
lpeeples Posted May 26, 2019 Author Share #5 Posted May 26, 2019 Doesn't the lens hood get in the way, taking the cap on and off? Link to post Share on other sites More sharing options...
Ranchhand Posted May 26, 2019 Share #6 Posted May 26, 2019 I use the Op/Tech Hood Hat-Mini on both the Q and Q2. This hood fits fine and can be easily slipped into a pocket when slid off of the lens and hood. Certainly easier than fumbling with the supplied hood. Also much cheaper to be replaced than the original cap. Louie Bob 3 Link to post Share on other sites More sharing options...
AnikiMu Posted May 26, 2019 Share #7 Posted May 26, 2019 Advertisement (gone after registration) 7 minutes ago, Ranchhand said: I use the Op/Tech Hood Hat-Mini on both the Q and Q2. This hood fits fine and can be easily slipped into a pocket when slid off of the lens and hood. Certainly easier than fumbling with the supplied hood. Also much cheaper to be replaced than the original cap. Louie Bob I use the same on the Q2. 2 Link to post Share on other sites More sharing options...
marchyman Posted May 26, 2019 Share #8 Posted May 26, 2019 (edited) 4 hours ago, lpeeples said: Doesn't the lens hood get in the way, taking the cap on and off? The cap is designed to fit over the lens without hood or over the hood. Edit: I keep the hood on my camera pretty much all the time. I put the cap over the hood when the camera is in its bag. When the camera comes out of the bag the cap comes off and stays in the bag. Edited May 26, 2019 by marchyman 1 Link to post Share on other sites More sharing options...
AnikiMu Posted May 27, 2019 Share #9 Posted May 27, 2019 (edited) 10 hours ago, marchyman said: The cap is designed to fit over the lens without hood or over the hood. Edit: I keep the hood on my camera pretty much all the time. I put the cap over the hood when the camera is in its bag. When the camera comes out of the bag the cap comes off and stays in the bag. Edited May 27, 2019 by AnikiMu Link to post Share on other sites More sharing options...
Colourise Posted May 27, 2019 Share #10 Posted May 27, 2019 (edited) @Ranchhand Does the Op/Tech Hood Hat-Mini fit over the lens hood of the Q2, and if so does it do it easily? thanks Edited May 27, 2019 by Colourise Link to post Share on other sites More sharing options...
AnikiMu Posted May 27, 2019 Share #11 Posted May 27, 2019 4 hours ago, Colourise said: @Ranchhand Does the Op/Tech Hood Hat-Mini fit over the lens hood of the Q2, and if so does it do it easily? thanks Yes, no problem Link to post Share on other sites More sharing options...
Colourise Posted May 27, 2019 Share #12 Posted May 27, 2019 @AnikiMu Thanks for the information Link to post Share on other sites More sharing options...
Overgaard Posted May 27, 2019 Share #13 Posted May 27, 2019 I think Leica can exchange the hood if it doesn't stay on. It works best on the shade, not so much on the lens itself, as far as I know. 1 Link to post Share on other sites More sharing options...
