reynoldsyoung Posted May 13, 2019 Share #1 Posted May 13, 2019 Advertisement (gone after registration) Am having difficulties setting the function buttons and the thumb wheel under "customize control". Can you direct me to a decent explanation of how to set them? Things like "Active Items Cannot be Deleted" and wheel assignment "auto"....just a little confused. Link to post Share on other sites More sharing options...
Advertisement Posted May 13, 2019 Posted May 13, 2019 Hi reynoldsyoung, Take a look here Q2 Function Buttons and Wheel. I'm sure you'll find what you were looking for!
Stephen_C Posted May 13, 2019 Share #2 Posted May 13, 2019 Do you have the downloadable user manual? If so, take a look at page 47 which explains the "Auto" business for the thumbwheel. "Active items cannot be deleted" means that you have already selected a function which you're trying to delete. Try to change the relevant function to something else and you should be able to delete the function you want to delete. (Sorry, it's quite difficult to explain it clearly. If you're still stuck post again and I, or someone else, will have another go at explaining it!) Stephen 1 Link to post Share on other sites More sharing options...
Leica Guy Posted May 14, 2019 Share #3 Posted May 14, 2019 (edited) I finally figured it out after my ch trial and error. In fact, I really like the function now that I understand it. Persevere and you’ll be rewarded. I do not understand AUTO, but I set the wheel assignment to Exposure Compensation so anytime I turn the dial it changes the exposure. I set other exposure related features like ISO for instance to be one of my selections. This works well for me. You can do everything with the thumbwheel and thumbwheel button that is assigned to the button. Pretty cool. Edited May 14, 2019 by iQ2 1 Link to post Share on other sites More sharing options...
Josh bear Posted May 14, 2019 Share #4 Posted May 14, 2019 17 hours ago, reynoldsyoung said: Am having difficulties setting the function buttons and the thumb wheel under "customize control". Can you direct me to a decent explanation of how to set them? Things like "Active Items Cannot be Deleted" and wheel assignment "auto"....just a little confused. Hi. RE Active Items Cannot be Deleted" it means that the button is currently set to the function you are trying to not make selectable. Solution is long press the button when camera is being used (I.e. not in menu mode) select one of the other options to set the button to activate another function. Then go back into the menu and then deselect the option you no longer want to be available with that button. Hopefully that makes sense. Josh Quote Link to post Share on other sites More sharing options...
reynoldsyoung Posted May 19, 2019 Author Share #5 Posted May 19, 2019 Big help, guys.....many thanks! I think I have a chance of getting there now!! 1 Link to post Share on other sites More sharing options...
Leica Guy Posted May 19, 2019 Share #6 Posted May 19, 2019 I discovered that if you choose exposure bracketing on the thumb button, it brings up all the parameters to set and AUTOMATICALLY puts the drive mode into bracketing. Pretty cool. I previously thought I had to select drive mode to bracketing even after I set up the bracketing parameters. Its simpler than I was making it. Link to post Share on other sites More sharing options...
reynoldsyoung Posted May 19, 2019 Author Share #7 Posted May 19, 2019 Advertisement (gone after registration) That's a very useful tool, IQ....many thanks!! Link to post Share on other sites More sharing options...
Leica Guy Posted May 19, 2019 Share #8 Posted May 19, 2019 3 hours ago, reynoldsyoung said: That's a very useful tool, IQ....many thanks!! IQ2. 😁 Link to post Share on other sites More sharing options...
ArtB Posted November 18, 2019 Share #9 Posted November 18, 2019 Why can't the thumb button be set to Drive mode, seems a shame, or even focus mode would also be useful. Also when setting that button exposure bracketing it does not seem well thought out, the wheel should have an "off" or cancel button otherwise you have to go to the menus to get out of bracketing mode. Custom button implementation needs an overhaul. Link to post Share on other sites More sharing options...
petermlamont Posted February 6, 2020 Share #10 Posted February 6, 2020 A bug? After the update I found that when in manual focus, the right button (in the wheel) no longer acts as a function button (and no longer selects ISO). It is stuck on the focus assistant magnifier. When the lens is set to auto focus, the button works as expected. Link to post Share on other sites More sharing options...
Leica Guy Posted February 7, 2020 Share #11 Posted February 7, 2020 3 hours ago, petermlamont said: A bug? After the update I found that when in manual focus, the right button (in the wheel) no longer acts as a function button (and no longer selects ISO). It is stuck on the focus assistant magnifier. When the lens is set to auto focus, the button works as expected. I don’t think it’s a bug. In macro mode it’s very important to at times keep the magnified image constant so one can see subtle movement by wind and take a photo when the image is still. Sharp. Pushing the thumb button accomplishes that perfectly. It’s a great improvement and operates very similar functionally to my Canon DSLR’s when zoomed. Link to post Share on other sites More sharing options...
mepaca Posted February 8, 2020 Share #12 Posted February 8, 2020 On 2/6/2020 at 9:59 PM, Leica Guy said: I don’t think it’s a bug. In macro mode it’s very important to at times keep the magnified image constant so one can see subtle movement by wind and take a photo when the image is still. Sharp. Pushing the thumb button accomplishes that perfectly. It’s a great improvement and operates very similar functionally to my Canon DSLR’s when zoomed. That's fine if that is what you want it to do. I, however, want a button to do what I assign it to do. Link to post Share on other sites More sharing options...
Leica Guy Posted February 8, 2020 Share #13 Posted February 8, 2020 I do find the implementation a bit odd and I agree it should do what’s assigned. Perhaps they’ll make the “stay magnified” mode a menu option in the future. For now, I consider this to be a big improvement for macro photography. Link to post Share on other sites More sharing options...
gotium Posted February 8, 2020 Share #14 Posted February 8, 2020 On 2/6/2020 at 3:33 PM, petermlamont said: A bug? After the update I found that when in manual focus, the right button (in the wheel) no longer acts as a function button (and no longer selects ISO). It is stuck on the focus assistant magnifier. When the lens is set to auto focus, the button works as expected. Woah, what? You mean you have to switch to autofocus to adjust ISO? Link to post Share on other sites More sharing options...
Leica Guy Posted February 8, 2020 Share #15 Posted February 8, 2020 I think it means that the thumb button is disabled from the custom functions when in MF. Again, not the way I think it should have been implemented. I’d have used the set button or up arrow on the 4-way controller. Give feedback. Maybe next release will improve implementation. Of course one can access the Quick menu and change settings there including ISO. Link to post Share on other sites More sharing options...
reynoldsyoung Posted March 17 Author Share #16 Posted March 17 Back again...years later...on both my Q3 43 and my Q2M, when I long press a button hoping to change the "action" of the button, all I get is a screen showing what "action" is currently selected. I don't get the full range of possible "actions" in order to make a change. Help!!! Link to post Share on other sites More sharing options...
reynoldsyoung Posted March 18 Author Share #17 Posted March 18 I figured it out, folks....I had turned off all the possible selections in the Custom area on the Q3 43. Turning them on gives me the full list of action when a function button is long pressed. The Q2M, however, on allows for 8 "actions" to be on at once. I made the selection of the 8 I wanted. A long press on the function button on the Q2 does NOT, however, show me the full list of the 8 I turned "on". Any thoughts there?? Link to post Share on other sites More sharing options...
