Bjoernyy Posted May 11, 2019 Share #1 Posted May 11, 2019 Advertisement (gone after registration) I am looking to buy a Leica Q2, as soon as the Leica is in stock at my local camera shop. So, I will also buy all accessory which is needed, like: - Camera strap: some strap, which protector the body and doesn‘t scratch the body at the connection for hand strap? - Screen protector, which one? - Second battery, original or not? - Flashlight, which is best compatible? - ... anything else, which is useful? Many thanks! Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2019 Posted May 11, 2019 Hi Bjoernyy, Take a look here Leica Q2 - recommended accessory? . I'm sure you'll find what you were looking for!
paul.bridges.3388 Posted May 11, 2019 Share #2 Posted May 11, 2019 I just picked up the Q2 grip at Leica Berlin. It makes the Q2 much nicer to hold (but does block SD card & battery). paul Link to post Share on other sites More sharing options...
Bjoernyy Posted May 17, 2019 Author Share #3 Posted May 17, 2019 Thank you. I don‘t like the grip. Maybe a thumps is an idea. But actually I am looking for a high quality leather strip which doesn‘t scratch the body... Link to post Share on other sites More sharing options...
paul.bridges.3388 Posted May 17, 2019 Share #4 Posted May 17, 2019 (edited) The thumb indent is plenty sufficient IMO. But, yes, the supplied strap does scratch the body. Silly design Edited May 17, 2019 by paul.bridges.3388 Link to post Share on other sites More sharing options...
microview Posted May 17, 2019 Share #5 Posted May 17, 2019 (edited) Art & Artisan straps won't do that. Highly recommended. I think the grip is pretty necessary and it's not much trouble to unscrew for SD card/battery access. Edited May 17, 2019 by microview Link to post Share on other sites More sharing options...
jbripley Posted May 17, 2019 Share #6 Posted May 17, 2019 I bought a thumb for my Q1, but I found that I preferred just using the indentation. I'm going to try a grip now with my Q2 and see if I like, by the way of using the Lim's half case I've seen mentioned in other threads. It can be ordered via Ebay, Amazon US and Etsy. 1 Link to post Share on other sites More sharing options...
scroy Posted May 18, 2019 Share #7 Posted May 18, 2019 Advertisement (gone after registration) I don't think there are any 3rd party batteries available for the Q2. It uses the same as the SL and seems to be in somewhat short supply at the moment, according to the Boston Leica Store. Link to post Share on other sites More sharing options...
sturkel Posted May 19, 2019 Share #8 Posted May 19, 2019 I did get the thumbs up for the Q2, I wasnt sure if I would like it since I alao hvae the Lim case. After a few hours of use it became a great addition to the case/camera. 1 Link to post Share on other sites More sharing options...
Leica Guy Posted May 19, 2019 Share #9 Posted May 19, 2019 55 minutes ago, sturkel said: I did get the thumbs up for the Q2, I wasnt sure if I would like it since I alao hvae the Lim case. After a few hours of use it became a great addition to the case/camera. Exactly my experience also. +1. Link to post Share on other sites More sharing options...
T00m Posted May 20, 2019 Share #10 Posted May 20, 2019 (edited) I have never felt the requirement of having a flash for Q1/Q2 as you can shoot near darkness. I‘m very happy with these straps: https://sailor-strap.com/ The gitzo Mini Traveller is Great to have with light/small Equipment. Edited May 20, 2019 by T00m 1 Link to post Share on other sites More sharing options...
ricky1981 Posted May 20, 2019 Share #11 Posted May 20, 2019 I had the grip on my Q and it was the first accessory I bought for my Q2 as it improves the handling significantly. I would like it to have ports for accessing the battery/SD card but that's only a minor inconvenience. I bought a strap from hyperion, much more comfortable than the one that came with the camera and I can wrap it around my hand for extra security when shooting one-handed. I bought a second battery which is essential for any camera, I haven't bothered with a flash as I've never learnt how to use them with great results and I just rely on the great low-light performance. Link to post Share on other sites More sharing options...
DonnaW Posted May 21, 2019 Share #12 Posted May 21, 2019 I used the match technical thumbs up on my old Q and felt it added significantly to my grip. When I received the Q2 I got an off brand from Amazon. It's not made as well and I'm sure it will not hold up, but the Leica thumbs up is still back ordered. If anyone has the Leica thumbs up already, can you tell if it's worth $250? The off brand was $85 and Match Technical now has one out, is well made and is also significantly cheaper. What do you think? I can still return the off brand. Link to post Share on other sites More sharing options...
Leica Guy Posted May 21, 2019 Share #13 Posted May 21, 2019 1 hour ago, DonnaW said: I used the match technical thumbs up on my old Q and felt it added significantly to my grip. When I received the Q2 I got an off brand from Amazon. It's not made as well and I'm sure it will not hold up, but the Leica thumbs up is still back ordered. If anyone has the Leica thumbs up already, can you tell if it's worth $250? The off brand was $85 and Match Technical now has one out, is well made and is also significantly cheaper. What do you think? I can still return the off brand. I have the Match Technical for my Q2. I had the similar one on my Q. It worked perfectly. For the Q2 they created a little more access to the zoom button. I like thar it’s solid brass. I have no need for the Leica one. Link to post Share on other sites More sharing options...
BulaBarry Posted May 23, 2019 Share #14 Posted May 23, 2019 I have not received my Q2 yet but so far I have ordered an extra battery, a Black LIM’s Half case, a black Artisan & Artist woven silk rope strap, a Manfrotto PIXI Mini Tripod, a Leica UVA II E49 protective filter, a Leica M10 Display Protection Foil, 2 SanDisk Extreme Pro SDXC UHS-II 64GB cards, and a DHG Achromatic Macro 200 (+5) filter (for macro photography). Excited & waiting for my Q2 to come. Link to post Share on other sites More sharing options...
reynoldsyoung Posted May 24, 2019 Share #15 Posted May 24, 2019 Extra original battery, Expert Shield screen protector, ThumbsUp thumb rest, A & A Strap (your choice), Lolumina soft release, Overgaard ventilated lens hood, B+W 49mm XS-Pro Clear MRC-Nano 007 Filter Link to post Share on other sites More sharing options...
DonnaW Posted June 21, 2019 Share #16 Posted June 21, 2019 On 5/20/2019 at 2:16 PM, T00m said: I have never felt the requirement of having a flash for Q1/Q2 as you can shoot near darkness. I‘m very happy with these straps: https://sailor-strap.com/ The gitzo Mini Traveller is Great to have with light/small Equipment. Don't you find that there is significant noise when shooting in near darkness? Link to post Share on other sites More sharing options...
Shuttermuse Posted June 21, 2019 Share #17 Posted June 21, 2019 With image stabilization you can shoot at 1/30 and wide open lens hand held and bump iso a bit, so a flash is not something you would need for this type of camera in my opinion. 1 Link to post Share on other sites More sharing options...
pico Posted June 21, 2019 Share #18 Posted June 21, 2019 8 minutes ago, Shuttermuse said: With image stabilization you can shoot at 1/30 and wide open lens hand held I would like to see a competent evaluation of such a claim. Link to post Share on other sites More sharing options...
malbooth Posted June 23, 2019 Share #19 Posted June 23, 2019 On 6/22/2019 at 5:06 AM, pico said: I would like to see a competent evaluation of such a claim. Hand held at 1/8 sec f/1.7 and ISO250 on a Q: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I'm sure the Q2 will be at least as good. 10 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! I'm sure the Q2 will be at least as good. ' data-webShareUrl='https://www.l-camera-forum.com/topic/297160-leica-q2-recommended-accessory/?do=findComment&comment=3764777'>More sharing options...
pico Posted June 23, 2019 Share #20 Posted June 23, 2019 WOW! Link to post Share on other sites More sharing options...
