Jackdenny Posted May 5, 2019 Share #1 Posted May 5, 2019 Advertisement (gone after registration) Dear all, first of all thanks in advance for your kind support. I have just bought a Leica M6 from an amateur and using it with a 50 Summilux. Analysing the camera, everything looked simply perfect and I bought it and the day after immediately tested it with a B&W roll to be self developed. That's exaclty when I realized that something was wrong: 1. My first issue has been related to film rewinding, after putting the camera on R mode, the lever was so tough to move and rotate and really really heavy 2. Then on film, the frames seem to be too spaced from each other as you can see in the picture below (at least 5 mm) 3. But what really concern me is the spring under the winder that seems to be damaged or somehow messy 4. Finally I realized putting another roll that during first 10 exposures the winder was light and creamy and after it becomes more and more to get tough as if it faces resistance somewhere. Do you know how can I sort this issue and how much could this cost? Thanks again for all your kind support and cooperation Daniele Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/296916-issue-with-m6-winder/?do=findComment&comment=3734945'>More sharing options...
Advertisement Posted May 5, 2019 Posted May 5, 2019 Hi Jackdenny, Take a look here Issue with M6 winder. I'm sure you'll find what you were looking for!
earleygallery Posted May 5, 2019 Share #2 Posted May 5, 2019 Unless you got a bargain I’d return that and get my money back. The rewinding mechanism can fail - I think it’s just a washer that usually needs replacing - and it looks like someone who doesn’t know what they’re doing has attempted to fix it, but have just done more damage. A CLA will bring the whole camera up to spec but it will be something like £3-500 or possibly more with your faults. Link to post Share on other sites More sharing options...
a.noctilux Posted May 5, 2019 Share #3 Posted May 5, 2019 (edited) Have a look here how the spring should be ( image from here ...) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Welcome here, As seen here is the first time that the spring which holds the film leader is in that state. I think you can try (if you want to keep the camera) first with a kind of fine screw driver to squeeze up that spring. Edited May 5, 2019 by a.noctilux Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Welcome here, As seen here is the first time that the spring which holds the film leader is in that state. I think you can try (if you want to keep the camera) first with a kind of fine screw driver to squeeze up that spring. ' data-webShareUrl='https://www.l-camera-forum.com/topic/296916-issue-with-m6-winder/?do=findComment&comment=3735031'>More sharing options...
Jackdenny Posted May 5, 2019 Author Share #4 Posted May 5, 2019 1 hour ago, a.noctilux said: Have a look here how the spring should be ( image from here ...) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Welcome here, As seen here is the first time that the spring which holds the film leader is in that state. I think you can try (if you want to keep the camera) first with a kind of fine screw driver to squeeze up that spring. Many thanks! I met a friend of mine showing me the same and I got really scared about the cost of the fix. Maybe I can try to relax the spring with a very kind of screw driver before to bring it to service. Since I have loaded another film with 10 shots already taken do you suggest me to finish it or remove it immediately and try to fix the spring? Thanks again for your support 🙏🏻 Link to post Share on other sites More sharing options...
a.noctilux Posted May 5, 2019 Share #5 Posted May 5, 2019 I'd rewind the film with care, so to be able to reuse the same film (just note the ten frames) and after the film removed try to gently straighten up the spring. If the operation is succesful, put the film in as usual, and "take 11 blank frames" with cap on the lens and 1/1000s. Link to post Share on other sites More sharing options...
Jackdenny Posted May 5, 2019 Author Share #6 Posted May 5, 2019 49 minutes ago, a.noctilux said: I'd rewind the film with care, so to be able to reuse the same film (just note the ten frames) and after the film removed try to gently straighten up the spring. If the operation is succesful, put the film in as usual, and "take 11 blank frames" with cap on the lens and 1/1000s. Many many thanks for your suggestions! Unfortunately even if I tried to relax the spring it does not come back into the right position as new and therefore the wonder does not work properly even breaking the film when rewinding it. I will bring it to the service but the guy who sold me that camera does not want to collaborate...so disappointed...will never buy something so expensive without a 1 year shop warranty... Thanks a lot for your feedback Link to post Share on other sites More sharing options...
plaidshirts Posted May 6, 2019 Share #7 Posted May 6, 2019 Advertisement (gone after registration) 7 hours ago, Jackdenny said: Many many thanks for your suggestions! Unfortunately even if I tried to relax the spring it does not come back into the right position as new and therefore the wonder does not work properly even breaking the film when rewinding it. I will bring it to the service but the guy who sold me that camera does not want to collaborate...so disappointed...will never buy something so expensive without a 1 year shop warranty... Thanks a lot for your feedback You just got the M6 and the seller won't collaborate? If I were in your shoes, I wouldn't relent until the seller refunded my money or at least bore the brunt of the repair. I hope you got a killer deal to absorb the added cost. Link to post Share on other sites More sharing options...
