ralphh Posted July 20, 2019 Share #81 Posted July 20, 2019 Advertisement (gone after registration) The profiles are up to you to set. Remember that everthing is included. It's very easy to set the Fn button how you like it and forget to save that into all your profiles. Link to post Share on other sites More sharing options...
Advertisement Posted July 20, 2019 Posted July 20, 2019 Hi ralphh, Take a look here Q2 firmware wishlist . I'm sure you'll find what you were looking for!
Giulio Zanni Posted July 20, 2019 Share #82 Posted July 20, 2019 Long exposure beyond the ridiculous 60 sec. What about the 4 minutes of the SL and M10? Link to post Share on other sites More sharing options...
bullmoon Posted July 21, 2019 Share #83 Posted July 21, 2019 Just got back form a short trip with the Q2. The most annoying thing I ran into was the focus field being some crazy place - probably by me inadvertently touching the screen. I'd love to be able to turn that off without having to disable the LCD altogether. Or, better yet, provide a quick way to center it when looking through the EVF - like I can with my 5D MIV. It is aggravating as hell! 1 Link to post Share on other sites More sharing options...
ralphh Posted July 21, 2019 Share #84 Posted July 21, 2019 1 minute ago, bullmoon said: Just got back form a short trip with the Q2. The most annoying thing I ran into was the focus field being some crazy place - probably by me inadvertently touching the screen. I'd love to be able to turn that off without having to disable the LCD altogether. Or, better yet, provide a quick way to center it when looking through the EVF - like I can with my 5D MIV. It is aggravating as hell! You can disable touch af while still being able to use the LCD. And double tap to centre stikk works (while the LCD is active). I found I was moving it around inadvertently too so I have it disabled. 1 Link to post Share on other sites More sharing options...
bullmoon Posted July 21, 2019 Share #85 Posted July 21, 2019 (edited) 26 minutes ago, ralphh said: You can disable touch af while still being able to use the LCD. And double tap to centre stikk works (while the LCD is active). I found I was moving it around inadvertently too so I have it disabled. Ah, I found that: Focusing / AF Touch off. OK - I'll try that. It would simply be much better if the EVF offered a way to center. I finally started using EVF extended and still no way to reset to center in the EVF. But that's an inconvenient workaround/compromise as well, especially when I suddenly need to compose a shot with the LCD - like over the heads of a crowd - and then I'd probably need AF Touch. It's a bummer the way it is implemented when the camera needs to be used in a variety of changing situations. That's my experience. It will cause missed shots or OOF shots. Edited July 21, 2019 by bullmoon Link to post Share on other sites More sharing options...
ralphh Posted July 21, 2019 Share #86 Posted July 21, 2019 (edited) 5 minutes ago, bullmoon said: I guess I have no idea how to do that. EVF only doesn't work that way. EVF Extended doesn't work that way. LCD and Auto don't give me that. And there's no explicit "disable touch" feature that I can find. So I'm lost as to how to do that with the Q2. If there is, I'd love to know how. It would simply be much better if the EVF offered a way to center. I finally started using EVF extended and still no way to reset to center in the EVF. But that's an inconvenient workaround/compromise as well, especially when I suddenly need to compose a shot with the LCD - like over the heads of a crowd. It's a bummer the way it is implemented when the camera needs to be used in a variety of changing situations. That's my experience. It will cause missed shots or OOF shots. It's not in the display settings. Go to menu page 1 -> focusing-> touch AF. Set it off Just took me 5 mins to find it again lol Edited July 21, 2019 by ralphh Link to post Share on other sites More sharing options...
ralphh Posted July 21, 2019 Share #87 Posted July 21, 2019 Advertisement (gone after registration) 8 minutes ago, bullmoon said: Ah, I found that AF Touch off. OK - I'll try that. It would simply be much better if the EVF offered a way to center. I finally started using EVF extended and still no way to reset to center in the EVF. But that's an inconvenient workaround/compromise as well, especially when I suddenly need to compose a shot with the LCD - like over the heads of a crowd - and then I'd probably need AF Touch. It's a bummer the way it is implemented when the camera needs to be used in a variety of changing situations. That's my experience. It will cause missed shots or OOF shots. I agree. I really wish the double tap on the screen to centre worked while looking through the evf. Or better still, if one could remap the set button to centre af instead of jump into video mode 2 Link to post Share on other sites More sharing options...
Leica Guy Posted July 22, 2019 Share #88 Posted July 22, 2019 2 hours ago, ralphh said: I agree. I really wish the double tap on the screen to centre worked while looking through the evf. Or better still, if one could remap the set button to centre af instead of jump into video mode +1000. Very frustrating with the present implementation. Yesterday I asked a companion to take the camera to capture a pic of my wife and me. I got it back and the focus point was way off in a corner. Lost some shots because of that. Thank goodness one was useful. The current implementation is dumb! 1 Link to post Share on other sites More sharing options...
Leica Guy Posted July 22, 2019 Share #89 Posted July 22, 2019 16 hours ago, bullmoon said: Ah, I found that: Focusing / AF Touch off. OK - I'll try that. It would simply be much better if the EVF offered a way to center. I finally started using EVF extended and still no way to reset to center in the EVF. But that's an inconvenient workaround/compromise as well, especially when I suddenly need to compose a shot with the LCD - like over the heads of a crowd - and then I'd probably need AF Touch. It's a bummer the way it is implemented when the camera needs to be used in a variety of changing situations. That's my experience. It will cause missed shots or OOF shots. An interesting side note. You have to have touch AF ON when using the FOTOS App in order to see and move the focus area. Otherwise, I leave Touch AF OFF. It also seems the Q2 is a step back from the Touch shutter feature. I’d like that to return like on the Q. 1 Link to post Share on other sites More sharing options...
Leica Guy Posted July 23, 2019 Share #90 Posted July 23, 2019 I just noticed on the new CL release: “Movable zoom position of the magnified live view in manual focus modeFocus manually and compose the shot at the same time.” I’ve wanted this for a long time for the Q. Read more: https://leicarumors.com/#ixzz5uVWCCL7d Link to post Share on other sites More sharing options...
