caspia1 Posted March 15, 2019 Share #1 Posted March 15, 2019 Advertisement (gone after registration) I have a Digilux 2. I would like to do some close up work. The close-up filter size is 72mm, I believe. Two questions. a)Where can I find one which is reasonable priced (a Leica one is very expensive) and (b), does anybody know the minimum focusing distance I can achieve? All advice will be gratefully appreciated! Link to post Share on other sites More sharing options...
Advertisement Posted March 15, 2019 Posted March 15, 2019 Hi caspia1, Take a look here 72mm close up filter . I'm sure you'll find what you were looking for!
ChrisRL Posted March 15, 2019 Share #2 Posted March 15, 2019 Caspia, hello Sorry, you must have the wrong forum.... this is the Leica section, where the words "Leica" and "resonably priced" are oxymoronic.... :-) Also the reason why Leica is "very expensive" is precisely because the optics that Leica has designed are not "reasonably priced". Therefore, since they make everything from scratch, their theory, and their practice, is that if you buy Leica, it will not look like anything else. So if you buy a Leica and then you put Canon or Tamron or Sigma glass on it... well, then, it's no longer Leica, is it? And I'm only half joking here. Just a little smile to go with the tears of Leica sticker shock... :-) Link to post Share on other sites More sharing options...
jaapv Posted March 15, 2019 Share #3 Posted March 15, 2019 Canon has a great diopter that fits the Digilux 2 to perfection. The 500D closeup lens. 77 mm, needs an adapter ring. Link to post Share on other sites More sharing options...
farnz Posted March 15, 2019 Share #4 Posted March 15, 2019 Hi, Caspia, the filter thread on the Digilux 2 is actually 69 mm, which is quite awkward because few companies made filters in 69 mm. Leica produced a superb close-up screw-on filter specially for the Digilux 2 called the Elpro-D although you might have difficulty finding one because they've been rare for quite a while but if you do find one I recommend getting it. If memory serves, Panasonic produced a similar 69 mm close-up filter for the Digilux 2's sister camera the DMC-LC1 so you might have luck that way too. If you can't find one of the above then I think you'll need a 69 to 72 step-up ring and use a 72 mm close-up filter. With my Elpro-D attached the Digilux 2's minimum focus distance is very short - something like 2 or 3 cm. Pete. Link to post Share on other sites More sharing options...
jaapv Posted March 16, 2019 Share #5 Posted March 16, 2019 You might find something interesting in our classifieds 1 Link to post Share on other sites More sharing options...
caspia1 Posted March 22, 2019 Author Share #6 Posted March 22, 2019 Thank you to all for your kind advice. When I find the best solution for my needs I will post it into this forum. Link to post Share on other sites More sharing options...
jrethorst Posted April 8, 2019 Share #7 Posted April 8, 2019 Advertisement (gone after registration) To confirm farnz's post, the Digilux 2 takes a 69mm filter. A small adaptor ring to 72mm will give you many more options for a close-up filter. What I use, though, is the very nice 69mm filter made by Panasonic, the DMW-LC69, for their version of the Digilux. It shouldn't be hard to find. Link to post Share on other sites More sharing options...
farnz Posted April 8, 2019 Share #8 Posted April 8, 2019 5 hours ago, jrethorst said: To confirm farnz's post, the Digilux 2 takes a 69mm filter. A small adaptor ring to 72mm will give you many more options for a close-up filter. What I use, though, is the very nice 69mm filter made by Panasonic, the DMW-LC69, for their version of the Digilux. It shouldn't be hard to find. To add to this, Panasonic also released a wide-anfle screw-in adaptor, the DMW-LW69 for the DMC-LC1, its sister camera to the Digilux 2. Beware not to mistake the the two if you find one. As far as I recall the DMW-LW69 increases the wide angle end to 23 mm although I don't recall seeing any glowing reports about it as a photographic tool. Pete. Link to post Share on other sites More sharing options...
