nicci78 Posted March 21, 2019 Share #41 Posted March 21, 2019 Advertisement (gone after registration) On 3/20/2019 at 10:09 AM, Mr.Q said: I find it amusing that some folks are OK with putting their fullframe M lenses on an APS-C body but not OK with cropping a fullframe image in camera or in post, effectively doing the same thing optically. I am OK with both. I advocate for 35mm crop with the Q, very practical. With stellar results. But I found that 50mm is a bit of a stretch and 75mm is really gimmicky. Link to post Share on other sites More sharing options...
Advertisement Posted March 21, 2019 Posted March 21, 2019 Hi nicci78, Take a look here Cropping - "Feature" or a Marketing Gimmick? . I'm sure you'll find what you were looking for!
Mr.Q Posted March 22, 2019 Share #42 Posted March 22, 2019 On 3/21/2019 at 7:50 AM, jaapv said: Some folks wouldn't do so if there were equivalent lenses in the CL system. For instance a Summilux TL 24 asph. "Unfortunately" we have to use M lenses. At least we don't lose megapixels by doing so. And, at least we have a choice, and are not limited by the camera concept. For the record: I am perfectly OK with whichever way anybody uses whatever camera. I'm just pointing out practicalities. Well noted, and the practicality of the Q2 is the ability to shoot usable images from 28mm to 50mm without the need to carry other lenses. Link to post Share on other sites More sharing options...
Mr.Q Posted March 22, 2019 Share #43 Posted March 22, 2019 2 hours ago, nicci78 said: I am OK with both. I advocate for 35mm crop with the Q, very practical. With stellar results. But I found that 50mm is a bit of a stretch and 75mm is really gimmicky. Perhaps on the Q1. On the Q2, you still get clean files at 75mm. I find the high ISO (25,600+) marketing to be much more gimmicky in that regard. The noise levels make the files unusable. Link to post Share on other sites More sharing options...
PMCG Posted April 24, 2019 Share #44 Posted April 24, 2019 I have a Q and a Q2 on order in the hopes that the 35mm crop will simulate a true 35mm lens. From reading this thread, however, I’m realizing that this is an unrealistic expectation. The barrel distortion from the wider angle lens will still be there in the 35mm crop, depending of course on the position of the crop. If one really wants the look of 35 or 50mm, is there really any alternative to using those primes? Link to post Share on other sites More sharing options...
dancook Posted April 24, 2019 Share #45 Posted April 24, 2019 (edited) 3 hours ago, PMCG said: I have a Q and a Q2 on order in the hopes that the 35mm crop will simulate a true 35mm lens. From reading this thread, however, I’m realizing that this is an unrealistic expectation. The barrel distortion from the wider angle lens will still be there in the 35mm crop, depending of course on the position of the crop. If one really wants the look of 35 or 50mm, is there really any alternative to using those primes? Position of the crop? Using crop modes it is only central. Edited April 24, 2019 by dancook Link to post Share on other sites More sharing options...
microview Posted April 24, 2019 Share #46 Posted April 24, 2019 And 35 crop won't differ from Q to Q2. As noted above, crop is centred but in processing you can see (if you are taking DNG images) full image and shift/vary crop rectangle according to preference. Link to post Share on other sites More sharing options...
