Hello 240 users out there. I was wondering if anyone has had this Issue: Cannot delete images from menu selection on camera.
Im hoping for assistance.
I cannot delete single or all  images from the camera using the menu option.
- I have the Firmware 2.0.5.0 and
- I shoot images in JPEG as  Well as RAAW for the same image.
To try to resolve this,
- I have reset the camera settings - to no avail.
- I have re-formatted the SD Cards - to no avail.
- I have tried deleting using different SD Cards- to no avail.
Can you assist ?
Here’s what I would suggest. Format the card in a computer with SD Formatter. Place the card back in the camera and format it with the camera. Thanked a few shots and try the delete button again.
okay.......cancel that. I see you have worked it out. :)
Edited by jdlaing
Thanks for that - I don't know what I was thinking ....Mondays...
  • Haha 1
21 hours ago, jdlaing said:
On the upside ... you didn’t accidentally delete an image you wanted to keep.
This is the danger of in-camera deletion!
In my experience much better to keep everything on the card, view the contents on your computer, and delete from there. Yes, this does mean carrying extra cards in case the one in the camera gets full.
On a related subject, I've always found it easier to copy the files from the card to the computer and import into Lightroom from there; importing direct from the card was i) slower and ii) it was not always certain to transfer every image. After the files have been copied onto the computer and imported, I delete the files from the card on the computer and re-format the card in the camera before use.
  • 5 years later...
Hey I hope this is solved-
If not:
1. Press Delete
2. SIngle ? If Single > press Set
3. If you need to delete all images > delete > all > set > with the wheel "yes" > set
Very save but a little complicated.
Cheers Peter
