diafreund Posted January 5, 2019 Share #1 Posted January 5, 2019 Advertisement (gone after registration) Hallo, ich habe eine neue M10P. Wenn ich den Deckel auf dem Objektiv lasse und mit 1/4000 sek. und Blende 22 belichte, dann ist das Bild mit unzähligen hellen Pixeln durchsetzt. Müßte das Bild nicht in seiner Gesamtheit schwarz sein? Bei Aufnahmen im Tageslicht sieht man das nicht. Ist das normal? Wer kennt das? Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2019 Posted January 5, 2019 Hi diafreund, Take a look here Sensor M10P viele Pixel bei Dunkelheit?. I'm sure you'll find what you were looking for!
Chaemono Posted January 5, 2019 Share #2 Posted January 5, 2019 Come again? Link to post Share on other sites More sharing options...
adan Posted January 5, 2019 Share #3 Posted January 5, 2019 (edited) Bei welcher <<ISO>>? Das ist <<digital noise>> - random triggering of individual pixel outputs from: camera heat, cosmic rays, electrical circuit noise, other sources. Or sometimes "hot pixels" that always output a strong signal regardless of how much light they are receiving. It is always present - but In daylight (or any light bright enough) the incoming signal (your exposure) vastly overpowers the noise. There is a very high "signal to noise" ratio. Therefore it is, for practical purposes, invisible. But if you give the sensor no light at all, the noise is all that remains, as speckles. Thus it is - in general principle - normal. https://en.wikipedia.org/wiki/Shot_noise It becomes more visible at high ISOs, because you are giving the sensor less picture and light to work with (less signal), but the noise stays at a fairly fixed level or floor (S/N ratio gets lower). When the camera "amplifies" the sensor signal to get a picture with only 1/32 the amount of light (at say, ISO 6400 vs ISO 200) - the noise will also get amplified 3200%. Edited January 5, 2019 by adan 2 Link to post Share on other sites More sharing options...
SMAL Posted January 5, 2019 Share #4 Posted January 5, 2019 Nimm mal die AUTO ISO raus und dann stell mal auf ISO100. Dann sind die weißen Punkte weg. Nennt sich Rauschen. Link to post Share on other sites More sharing options...
duoenboge Posted January 5, 2019 Share #5 Posted January 5, 2019 Ist das jetzt der neuste Trend, fotografieren mit am Objektiv angesetzten Deckel? Ich habe mal vergessen die Batterie einzulegen. Kam auch nichts dabei raus. 😪 2 Link to post Share on other sites More sharing options...
Talker Posted January 6, 2019 Share #6 Posted January 6, 2019 Obwohl, das sicherere Verfahren dürfte für diesen Test natürlich das, ohne eingelegten Akku sein. von Batterien ist ohnehin abzuraten. Die passen nur ein einziges Mal in den Akkuschacht. Link to post Share on other sites More sharing options...
M11 for me Posted January 6, 2019 Share #7 Posted January 6, 2019 Advertisement (gone after registration) Nimm doch mal ein solches Deckel-Bild und lass es vergrössern auf 1m mal 70cm. Ich kann mir verstellen, dass wenn du die richtige Galerie findest, du noch berühmt werden kannst. Wäre doch cool. Einfach Deckel drauf und abdrücken. Mach 10 solcher Bilder und häng sie nebeneinander auf. Sie sind sicher alle anders. Schau mal hier: susanmikula.com Bilder der Künstlerin und Partnerin von Rachel Maddow, die man vielleicht besser kennt. Die Bilder sind alle komplett unscharf. Mit deinen Rauschbildern hast du etwas ähnliches. Link to post Share on other sites More sharing options...
Apo-Elmarit Posted January 6, 2019 Share #8 Posted January 6, 2019 Was soll man jetzt davon halten? https://www.l-camera-forum.com/topic/292953-sensor-m10p-mit-pixelfehlern-bei-dunkelheit/ Link to post Share on other sites More sharing options...
ArminB Posted January 6, 2019 Share #9 Posted January 6, 2019 vor 1 Stunde schrieb Macro-Elmarit: Was soll man jetzt davon halten? https://www.l-camera-forum.com/topic/292953-sensor-m10p-mit-pixelfehlern-bei-dunkelheit/ diafreund schrieb doch in diesem Post, dass er die o.g. Frage versehentlich im internationalen Forum gepostet und gleichzeitig um Löschung gebeten hat. Stattdessen wurde die Frage ins deutschsprachige Forum verschoben und lässt den Verfasser nun ziemlich doof aussehen. Es war ein einfacher Bedienungsfehler - das Problem ist längst gelöst! Vielleicht könnte die Moderation das in Ordnung bringen... 2 Link to post Share on other sites More sharing options...
Apo-Elmarit Posted January 6, 2019 Share #10 Posted January 6, 2019 Eben. Link to post Share on other sites More sharing options...
