Firmware updates Leica M10 (2.6.5.0) and Leica M-10P (2.6.5.1)
Didn't get much attention during photokina:
Both the Leica M10 and the Leica M10-P have firmware updates:
» Leica M10 Version 2.6.5.0 (Download)
Details and installation instructions
» Leica M10-P Version 2.6.5.1 (Download)
Important: If your are using the existing Leica M app you shouldn't update.
After the update your Leica M10 / M10-P will work only with the new Leica Fotos App
Improvements:
  • NEW: Compatible with the new Leica FOTOS app
    Connect your smartphone to your Leica camera
  • NEW: QR Code for all Leica Cameras
    Easy pairing of smartphone and Leica cameras.
  • NEW: 1-Click Connection with FN-Button WLAN starts without submenus on FN-button.
  • NEW: Fixed WLAN name and password
    No submenus for setting name and password.
  • NEW: No submenus for mode settings
    No submenus for setting a connection mode.
Discussion about the Leica M10 firmware here
My Leica M app was updated a couple of days ago to version 1.1.2. The purpose of the update was stated to be “Supports new firmware 2.6.5.0 or higher”
Has Leica now rescinded this statement? Or does the updated M app still support M10 firmware 2.6.5.0?
But answer came there none.
It turns out that the warning not to update to 2.6.5.0 is indeed outdated and wrong, at least as far as iOS is concerned.
I updated my M10 today and can report that it works just fine with the updated Leica M app on my iPhone.
It seems the 1-click WiFi startup from the function button isn't there yet.  I press the function button and nothing happens.  It's not in custom controls.  In fact I prefer to keep the function button for bringing up magnification in liveview.  Two button presses in the favorites menu is fast enough for me.
But am I missing something?
The updated „Leica M App“ works with the M10 updated to Firmware 2.6.5.0, so the warning in the instructions for 2.6.5.0 - which was justified before - is not valid anymore. I compared it to the new Phots App here: https://www.l-camera-forum.com/topic/289858-leica-m10-firmware-2650-released/?p=3603039
After updating M10 to version 2.6.5.0 the shutter speed display can now show 1/25 sec (!) when looking through the viewfinder (OVF) - at the same time the LCD screen back on camera shows the common used 1/24 sec as also will be "stamped" on the picture when reviewing.
Displaying 1/24 sec through the viewfinder will still be possible when the exposure is measured to be exactly 1/24 sec.
I know that the camera calculates all possible shutter speeds - but to avoid confusion it normally should "round" (filter) the figure to a common used value before presentation - in this case 1/24 sec (although the factual shutter speed will be calculated as 1/25 sec).
Perhaps a minor bug to be corrected in the next update  :).
Best regards P
Still no manual lens ID for Summilux 35 double aspherical. Very disappointed. Emailed Leica USA months ago and they assured me it will be in next update. But now says Customer Care lost argument with Product Management and don't understand why they won't include it. I need it to identify its photos from other Lux 35's.
Best regards P
I posted something last month about the 10-P reading in aperture priority 15-24-25-30-45-50-60 so with the extra 25 and 50. If I shoot at 25, the EXIF file says 24 so I think it is just a bug and like any bug, it seems it has now spread to the M10 ..
Thanks Fedro
I can confirm your figures.
This is very important info because this means that the camera itself will not be defect.
Showing 15-24-25-30-45-50-60 in the LED-display is not a big deal - whereas a defect camera would be a completely different story.
It must be a bug  :wacko: - Let's be glad that it does not show all values between 4 minutes and 1/4000 sec.
BR P
Exactly ... two is company :)
I was going to show it to the Leica store at some point, will let you know what they say ..
Cheers
Further two divergences between the LED-display and the LCD-screen when in aperture priority mode:
LED will show 1.5" instead of 1" (therefore 1.5" applies for both 1" and 1.5").
LED will show 2 instead of 3 for ⅓ sec (therefore 2 applies for both ½ and ⅓ sec).
So, out of many, many values 4 readings will deviate with half a stop.
On my personal M10 all other shutter speed readings seems to correspond.
I found another M10 in a local store that also was able to show 1/25 sec :-)
But it really is strange to have two different readings at the same time ...
Best regard
Are you sure, there is no other way to identify the 35mm Summilux Aspherical from other 35mm Summilux asph versions than the EXIF? Absolutely no difference in results? If so it must have been horrible for users of both versions during times of film.
Sure, on a shot by shot basis it can be relatively easy to identify especially when there is sample from another lens to compare with. For example, the color of the 35AA is cooler than the FLE and warmer than the none-ASPH. I don't know how its color compares with the ASPH version though. Its bokeh is distinguishable from the others too, especially that of the OOF light source (orbs ?). But I certainly would like to have it in the exif. No reason why it shouldn't. It was in all the previous digital Ms.
