Einst_Stein Posted September 29, 2018 Share #1 Posted September 29, 2018 Advertisement (gone after registration) I have B+W 82mm polarizers that fit SL zooms, but rarely use it. It is just inconvenient, besides, I didnt use polarizer on M either, so I basically ignored the benefit. How do you experts do with polarizer on SL? Link to post Share on other sites More sharing options...
Advertisement Posted September 29, 2018 Posted September 29, 2018 Hi Einst_Stein, Take a look here Using polarizer with lens hood?. I'm sure you'll find what you were looking for!
LD_50 Posted September 29, 2018 Share #2 Posted September 29, 2018 Attach to lens. Shoot. Is there a question about the lens hood? Link to post Share on other sites More sharing options...
Einst_Stein Posted September 29, 2018 Author Share #3 Posted September 29, 2018 Attach to lens. Shoot. Is there a question about the lens hood? Attach to lens. Shoot. Is there a question about the lens hood? I am not sure you really understand the issue yet. Have you ever used any camera with lens hood? Link to post Share on other sites More sharing options...
LD_50 Posted September 29, 2018 Share #4 Posted September 29, 2018 Have I used a camera with lens hood? No. Have I used lenses with lens hoods? Yes. Have I used lenses with lens hoods and filters? Yes. Link to post Share on other sites More sharing options...
Einst_Stein Posted September 29, 2018 Author Share #5 Posted September 29, 2018 (edited) Have I used a camera with lens hood? No. Have I used lenses with lens hoods? Yes. Have I used lenses with lens hoods and filters? Yes. Seems you have never own a modern fixed lens camera. That OK, irrelevant. But I am curious how do you use the polarizer on the lens that has a dedicated lens hood ( FYI, attached to the outer ring of the lens). Edited September 29, 2018 by Einst_Stein Link to post Share on other sites More sharing options...
dkCambridgeshire Posted September 29, 2018 Share #6 Posted September 29, 2018 Acquire a Lee hood and adapt it to the SL lens … and use a Lee polariser dunk 2 Link to post Share on other sites More sharing options...
LD_50 Posted September 29, 2018 Share #7 Posted September 29, 2018 (edited) Advertisement (gone after registration) I don’t use a lens hood with filter systems that are incompatible. Pretty simple. And I own a “modern fixed lens camera” (RX1) as well as modern ILCs (MP240 and SL). That’s irrelevant to the question you sort of asked. Edited September 29, 2018 by LD_50 Link to post Share on other sites More sharing options...
IkarusJohn Posted September 29, 2018 Share #8 Posted September 29, 2018 I use a polariser on the SL lenses. As the hoods are so large, and it is impossible to fit and adjust the polariser with the hood on, I adjust the polariser first (you have to have the hood off to attach the polariser). Often, the polariser is of most effect when a hood is also needed, so once the polariser has been adjusted how I want it, I put the hood back on. Not sure there’s another way of doing it. 1 Link to post Share on other sites More sharing options...
mmradman Posted September 29, 2018 Share #9 Posted September 29, 2018 I use a polariser on the SL lenses. As the hoods are so large, and it is impossible to fit and adjust the polariser with the hood on, I adjust the polariser first (you have to have the hood off to attach the polariser). Often, the polariser is of most effect when a hood is also needed, so once the polariser has been adjusted how I want it, I put the hood back on. Not sure there’s another way of doing it. There is, some recent Pentax hoods have sliding slot to provide access to polarizing filter. I believe these are kind of wide- mormal prime/zooms. Long fast lens with big front elements usually have filter drawer at the back. Polarisers are usually controlled via external wheel geared to filter inside. Link to post Share on other sites More sharing options...
mmradman Posted September 29, 2018 Share #10 Posted September 29, 2018 Example of drop-in for long lenses. https://www.amazon.co.uk/Nikon-52MM-C-PL1L-DROP-FILTER/dp/B00009R96G Pentax hood slider. http://www.booleansplit.com/?tag=lens-hood Link to post Share on other sites More sharing options...
Einst_Stein Posted September 29, 2018 Author Share #11 Posted September 29, 2018 Acquire a Lee hood and adapt it to the SL lens … and use a Lee polariser dunk Thanks, this will be a useful and might be expensive solution. Link to post Share on other sites More sharing options...
Einst_Stein Posted September 29, 2018 Author Share #12 Posted September 29, 2018 Example of drop-in for long lenses. https://www.amazon.co.uk/Nikon-52MM-C-PL1L-DROP-FILTER/dp/B00009R96G Pentax hood slider. http://www.booleansplit.com/?tag=lens-hood Thanks a lot for the link. i think these requies a fit lens or fit hood. The filter acceess window is a good idea. I am gonibg to ask a friend in China to make a sample with 3D printer to fit SL. Link to post Share on other sites More sharing options...
MarkP Posted September 30, 2018 Share #13 Posted September 30, 2018 (edited) The 82mm B+W lens hood can be screwed onto a PL filter fitted to the 24-90 SL, and the whole filter hood combo rotated as required. I had one sitting around at home for years from an old video camera lens. There is NO vignetting whatsoever with one filter under the hood (which is much more compact than the 24-90 hood). I’ll post a photo and the hood code number when I’m back home in the next day or so. Edited September 30, 2018 by MarkP Link to post Share on other sites More sharing options...
MarkP Posted October 3, 2018 Share #14 Posted October 3, 2018 Better pics to follow when I have time. Can't find the PL (think it's in the car ) so I've attached a UV filter to demonstrate. The B+W hood doesn't have a code stamped on it. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/289999-using-polarizer-with-lens-hood/?do=findComment&comment=3605558'>More sharing options...
Einst_Stein Posted October 4, 2018 Author Share #15 Posted October 4, 2018 Follwoing your previous message, I found these. I would assume the round shape has less flare protection on 24-90mm? The lotus shape may be closer to 24-90mm original shade, but requires two rotating actions, first to set the polarizer orientation, the second to adjust the rotus orientation. ... may not be more convenient than simply rmove the shade, the put it back. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/289999-using-polarizer-with-lens-hood/?do=findComment&comment=3605923'>More sharing options...
MarkP Posted October 4, 2018 Share #16 Posted October 4, 2018 Well I've had no significant flare problems with this hood screwed into a PL filter on the 24-90 SL. The lens is relatively flare resistant. Everything is, of course, a trade-off but when I want to use a PL filter this is much easier than fiddling around the lens' original hood. Furthermore, it does make the 24-90 a much more compact package than with the original hood fitted, still affords protection to the lens, so I use it quite often even when not using a PL filter. I thought it was long discontinued. Mine doesn't have a code number but I think is the same as this one: https://www.bhphotovideo.com/c/product/11202-REG/B_W_65041222_82mm_Screw_In_Metal_Wide.html Link to post Share on other sites More sharing options...
Krauklis Posted October 4, 2018 Share #17 Posted October 4, 2018 (edited) @MarkP Thanks for posting the photo and the additional information. I've just ordered the B+W screw-in hood. As soon as I have used the hood and the polarizer I might report on my experience with them. krauklis Edited October 4, 2018 by Krauklis 2 Link to post Share on other sites More sharing options...
