designdog Posted June 7, 2018 Share #1 Posted June 7, 2018 Advertisement (gone after registration) Just got mine, and have a few questions. First, the screw does not screw into the camera with the "shim" panel included. Works fine without it though. What is that shim for, then? Second, and most troublesome, I can't seem to "unscrew" or remove the screw that comes with the cover. I want to do this because I bought some d-ring type screws for easy opening. It almost looks like there is a black ring at the base that retains the Leica screw. I certainly don't want to rip open the new half case! Any thoughts? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted June 7, 2018 Posted June 7, 2018 Hi designdog, Take a look here Leica Leather Protector Half Case. I'm sure you'll find what you were looking for!
marcg Posted June 7, 2018 Share #2 Posted June 7, 2018 What make is it? Link to post Share on other sites More sharing options...
designdog Posted June 7, 2018 Author Share #3 Posted June 7, 2018 What make is it? It is the Leica M10 "Leather Protector" which is a half case with the separate flap in back that protects the screen. Made by Leica. Link to post Share on other sites More sharing options...
bencychin Posted June 7, 2018 Share #4 Posted June 7, 2018 It is the Leica M10 "Leather Protector" which is a half case with the separate flap in back that protects the screen. Made by Leica. Please read Best Half Case for M10 post # 53. It explained how to remove the screw. There is a black rubber ring holding the screw that you need to remove. Link to post Share on other sites More sharing options...
Gobert Posted June 7, 2018 Share #5 Posted June 7, 2018 And place another to prevent falling out. Mine goes perfect in with the shim panel. In the meantime I’ve glued it. Link to post Share on other sites More sharing options...
mdemeyer Posted June 8, 2018 Share #6 Posted June 8, 2018 You only use the shim when not using the rear flap. Not both at once. Link to post Share on other sites More sharing options...
designdog Posted June 8, 2018 Author Share #7 Posted June 8, 2018 Advertisement (gone after registration) You only use the shim when not using the rear flap. Not both at once. Thanks! Makes perfect sense! However, I have found that, with the shim and the rear flap both in, the screw cannot each the tripod hole. A detriment for screwing it in, yes, but a boon if you want to leave the screw in (and not risk tearing up your case) and simply not screw it at all. As long as the fit is tight enough, thats how I will do it... Link to post Share on other sites More sharing options...
Gobert Posted June 8, 2018 Share #8 Posted June 8, 2018 In case of tripod use I apply an RRS bottom plate. Link to post Share on other sites More sharing options...
Guest Posted July 1, 2018 Share #9 Posted July 1, 2018 I use mine without the shim or back flap......works good for me Neil Link to post Share on other sites More sharing options...
