  • 2 weeks later...
I am using the Lee Seven5 System for my Leica M-System without any problem, but I think that You mean perhaps the 100mm System which I use only the DSLR but I think that even the 100mm System is not that heavy that You would run into problems as long as You are not using one of the Lee lens hoods.
Edited by strohscw
Is anyone worried about putting the Lee system with heavy glass on the front of a small Leica M lens? (As opposed to the SL or S lenses)? Do you think it is too much weight for the focusing system?
No worries whatsoever.
I am talking about the 4x4 inch system, which I think is 100mm.  The graduated ND filters are larger to allow up and down adjustment, and I just wondered if anyone else had used this....  I don't even know if there is a smaller sized set...
Thanks for responding!
