My dealer just sent me a replacement 280mm Apo f/4 for the one that had fungus in it.  This newer one is fungus-free but has cleaning marks on the front element.  It also came with a bill of sale from Leica for a CLA that occurred in 2014 which details:
​"Clean lube and adjust haze/coating degradation.  The factory has provided the following evaluation:  Clean optics as well as possible, some residue will remain******** Adjust focusing ring clean optics, adjust all parts"
The lens smells a little moldy.  Should I be concerned about the haze/coating degradation that was apparently repaired?  I'm not sure what residue they are referring to when they say that some will remain.
​Just to be clear, this lens was sold as being in excellent condition.
I should clarify that I don’t see anything particularly wrong with the glass, but I’m not an expert. There is a fair amount of dust and one hairline scratch on the front element (the one below the protective element). The aperture blades and free of oil and the glass looks clear to me.
I'd send it back again...
I mean, probably it's just fine (the tiny mark on the front element means nothing, I would be more concerned about the coating degradation, if it's minimal it's a not problem, otherwise might be...), but, you see, if they say it was mint and you've paid accordingly to that...
Edited by Steve McGarrett
I just went and tested the lens on my SL.  I used a tripod and shot subjects at varying distances, and to make things interesting I also took shots with my 90mm Apo-Summicron M at f/4.  I found that the 90mm is sharper and resolves more detail, and that the colors are nearly identical between the two lenses.  I was under the impression that the 280mm Apo f/4 should out-perform and out-resolve the 90 Apo, so maybe there is something wrong with the lens that is preventing it from achieving its maximum performance?
...The factory has provided the following evaluation:  Clean optics as well as possible, some residue will remain******** Adjust focusing ring clean optics, adjust all parts"
Over the years I had several lenses cleaned by Leica in Solms, and the above quoted evaluation is what they always say. I guess they say what they say for liability reasons. With some older lenses, it will not be possible to clean them to the fullest extent, which is why they indicate 'some residue will remain'. However, that does not mean that some residue will in fact remain, but merely that in some cases some residue may remain.
So if your lens is clean, everything is fine.
Here are download links to the raw files.  The 280mm and 90mm were both shot on an SL on a tripod at f/4.  As a bonus, I've added a link to download a shot from the 75mm Summilux, handheld and taken at f/4 (but from a few days ago).
280mm Apo f/4 @ f/4:  https://we.tl/0Dg8vEsAyX
90mm Apo-Summicron Asph M @ f/4:  https://we.tl/9qL6Ug1M0m
75mm Summilux M @ f/4:  https://we.tl/vJoP4lxPnJ
​While sharp, I found this copy of the 280mm Apo underwhelming compared to the 90 Apo.  It seems to be about equal in sharpness to the 75 lux at f/4.
Looking at the above 2 files at 200%, there's nothing wrong with your lens.  In each image, the section that's in focus is sharp.  However, in each instance, I'd guess the plane of focus isn't where you intended it to be.
The SL offers decent manual focusing cues.  Using the SL and the 280mm f/4 at closer distances, peaking cues that occur either in front of or behind the intended focal plane (or both) can sometimes be deceptive. Peaking, magnification, and a bit of extra care are all required in order to fully exploit the sharpness of this lens on the SL.
I now use an a7r ii with this lens, and I have to use both peaking and second-level magnification to get the most out of it.
I didn't use peaking- I zoomed in and focused right on the eye.  Just to be sure that I got on in perfect focus, I took about 20 shots and bracketed.  The focal plane is right on the eye in those photos... I just think that the 90 Apo out-resolves this particular copy of the 280mm Apo.  It's pretty clear when looking at details like the eyebrows and cornea.
The 2 photos have little contrast. They are ok, I think. Focussing is not the question either.
Isn´t it in this case better to chose a landscape example? With high contrasts, perhaps causing flare?
The problem area is the frontlens (cleaning marks, hairline).
Jan
Forget Leica "service" for this lens.
My dealer had a 280/4 APO with internal haze that he sent to me for evaluation.  Turns out the internal haze resulted in a loss of contrast, so he instructed me to send it to Leica USA for cleaning (at his expense).  It returned with the same internal haze, same loss of contrast.  I then sent it to DAG who returned the lens minus the haze, at lower cost and shorter turnaround, and its performance is now everything I expect it to be.
So maybe the copy I had had lower contrast than it should have. I took many more photos with it including some shots of leaves. At f/4 and minimum focusing distance, my 90 apo (cropped to match the 280mm field of view at mfd) was far sharper than the 280mm and had a more vibrant color reproduction.
