I have a Leica SL and CL and use the CL generally as a light weight back up. The SL works very well with a Nikon compatible Profoto Air TTL trigger but when I put the trigger on the CL, which seems to have exactly the same pin configuration, the flash will not fire. The link between  trigger and flash works fine; it's the connectivity between the CL and the trigger that seems to be the problem.
Any ideas or suggestions welcome.
Thanks
David
This topic is now closed to further replies.
