ShivaYash Posted February 15, 2018 Share #1 Posted February 15, 2018 Advertisement (gone after registration) Hello Any experience of this lens? I am looking for a nice compact 35 or 50 to complement the R6.2 I just ordered. Thx Link to post Share on other sites More sharing options...
Advertisement Posted February 15, 2018 Posted February 15, 2018 Hi ShivaYash, Take a look here Leica R f/2.8 35mm Elmarit-R. I'm sure you'll find what you were looking for!
a.noctilux Posted February 15, 2018 Share #2 Posted February 15, 2018 (edited) Before you ask, here is the focus "bonus" : https://www.l-camera-forum.com/topic/275034-35mm-elmarit-r-iii-min-focus-beyond-min-focus-mark/ ...if that's your lens to come. More infos in Wiki: https://www.l-camera-forum.com/leica-wiki.en/index.php/35mm_f/2.8_Elmarit-R_II https://www.l-camera-forum.com/leica-wiki.en/index.php/35mm_f/2.8_Elmarit-R_III My choice since 1990's is Summicron-R 2/35 II: https://www.l-camera-forum.com/leica-wiki.en/index.php/35mm_f/2_Summicron-R_II see comments and links there... Edited February 15, 2018 by a.noctilux Link to post Share on other sites More sharing options...
TomB_tx Posted February 15, 2018 Share #3 Posted February 15, 2018 I also chose the Summicron over the 35 Elmarit-R, but the Elmarit is more compact and is likely sharper. Link to post Share on other sites More sharing options...
ShivaYash Posted February 15, 2018 Author Share #4 Posted February 15, 2018 I also chose the Summicron over the 35 Elmarit-R, but the Elmarit is more compact and is likely sharper. Yes the extra stop is always handy. Link to post Share on other sites More sharing options...
Keith (M) Posted February 15, 2018 Share #5 Posted February 15, 2018 I bought a 35mm Elmarit-R to got with my R5 last summer. Was surprised to find it would focus down to circa 20cm - as discussed here. Examples on Flickr with my R5 and the Elmarit. Delighted with it (and my other Elmarits - the 60mm Macro and the 90mm). Link to post Share on other sites More sharing options...
earleygallery Posted February 15, 2018 Share #6 Posted February 15, 2018 I have the earlier version Summicron R 35 which is a lovely lens, although quite a heavy lump of glass! I remember a while ago, a pro (can't remember who but a photojournalist) who moved from Leica to Nikon saying he kept a Leica R body just to use this lens with. I also have the Summicron 50 which is compact and relatively light. Can't really go wrong with any of the above. Link to post Share on other sites More sharing options...
ShivaYash Posted February 16, 2018 Author Share #7 Posted February 16, 2018 Advertisement (gone after registration) Is there much difference between the first and second versions of the 35 f/2.8? The 11101 vs 11201 I mean? Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Keith (M) Posted February 16, 2018 Share #8 Posted February 16, 2018 According to E Puts, the second version had "all metal mounts and a small change in the optical prescription with a tiny air space between 2nd and 3rd elements." 11101 has Series 6 filters, 11201 is two-cam and Series 7 filters. The one I have is from the last batch of Series III, takes E55 filters and has a built-in hood. To quote Erwin again - "Close up performance is excellent and if this is the required application, the Elmarit should be preferred over the Summicron-R 35mm." 1 Link to post Share on other sites More sharing options...
ShivaYash Posted February 16, 2018 Author Share #9 Posted February 16, 2018 According to E Puts, the second version had "all metal mounts and a small change in the optical prescription with a tiny air space between 2nd and 3rd elements." 11101 has Series 6 filters, 11201 is two-cam and Series 7 filters. The one I have is from the last batch of Series III, takes E55 filters and has a built-in hood. To quote Erwin again - "Close up performance is excellent and if this is the required application, the Elmarit should be preferred over the Summicron-R 35mm." And all versions will work (mount) on the R6.2? Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
wizard Posted February 16, 2018 Share #10 Posted February 16, 2018 And all versions will work (mount) on the R6.2? Sent from my iPhone using Tapatalk In principle, yes, as long as they have the R-cam. Early models produced for the Leicaflex and Leicaflex SL, SL2 did not have that R-cam, but it could be retrofitted, so just make sure the R-cam is present. Link to post Share on other sites More sharing options...
ShivaYash Posted February 16, 2018 Author Share #11 Posted February 16, 2018 In principle, yes, as long as they have the R-cam. Early models produced for the Leicaflex and Leicaflex SL, SL2 did not have that R-cam, but it could be retrofitted, so just make sure the R-cam is present. What does this R cam look like? Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
masjah Posted February 16, 2018 Share #12 Posted February 16, 2018 What does this R cam look like? Sent from my iPhone using Tapatalk Probably easier for you to see than for us to try to describe! If you google Leica R Cams you should soon come up with some illustrations. Link to post Share on other sites More sharing options...
Keith (M) Posted February 16, 2018 Share #13 Posted February 16, 2018 What does this R cam look like? Sent from my iPhone using Tapatalk Here's one I prepared earlier... AFAIK, this is a 3-cam. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/281842-leica-r-f28-35mm-elmarit-r/?do=findComment&comment=3462792'>More sharing options...
TomB_tx Posted February 16, 2018 Share #14 Posted February 16, 2018 (edited) Here's another illustration: First is a 3-cam 35mm Summicron. The two silver cams are true "cams" with a sloping surface. The original Leicaflex used one of them, the LeicaflexSL used only the added 2nd cam, and the LeicaflexSL2 used both of the sloping cams. The R-cam (needed for R bodies) is harder to see - a thin stepped "cam" just inside the silver cam on the left in this picture: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! You can see it clearer in this lens, which is an "R-cam only" 50 Summicron I got with my R4. I circled the cam to make its location obvious. All of the R bodies only need the R-cam, but it won't give aperture information to any of the Leicaflex models. Edited February 16, 2018 by TomB_tx 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! You can see it clearer in this lens, which is an "R-cam only" 50 Summicron I got with my R4. I circled the cam to make its location obvious. All of the R bodies only need the R-cam, but it won't give aperture information to any of the Leicaflex models. ' data-webShareUrl='https://www.l-camera-forum.com/topic/281842-leica-r-f28-35mm-elmarit-r/?do=findComment&comment=3462850'>More sharing options...
ShivaYash Posted February 17, 2018 Author Share #15 Posted February 17, 2018 Thanks for the replies. Whilst I’m delighted with my new R6.2 body in chrome, I was hoping to pick up some cheap lenses, cheap in comparison to the M ones. But I fear I’m late to the party, and prices have shot up. Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Keith (M) Posted February 17, 2018 Share #16 Posted February 17, 2018 Aperture (London) have some 'user' grade R lenses listed at reasonably low prices. Link to post Share on other sites More sharing options...
ShivaYash Posted February 17, 2018 Author Share #17 Posted February 17, 2018 Aperture (London) have some 'user' grade R lenses listed at reasonably low prices. Thanks, I need to update my signature. I'm now based in Berlin. But I go to London fairly often. Will check it out. Link to post Share on other sites More sharing options...
jomocovi Posted February 21, 2018 Share #18 Posted February 21, 2018 Both Elmarit R 35 II and III are excellent lenses I have used. They have quite different character just like 50mm Cron I and II. Elmarit 35 II has superb built, nice shape, smooth tone rendering and vintage look in the image. The III has sharper image and more contrast. Definitively it has a modern look. If I choose one now, I go for the II though I actually own a III. Link to post Share on other sites More sharing options...
