robsonj Posted February 21, 2018 Share #21 Â Posted February 21, 2018 Advertisement (gone after registration) Paint looks a bit shiny. Try rubbing over it with ScotchBrite. Would matte paint be a better option? Link to post Share on other sites More sharing options...
Advertisement Posted February 21, 2018 Posted February 21, 2018 Hi robsonj, Take a look here Coding CV lenses for M10. I'm sure you'll find what you were looking for!
rramesh Posted February 21, 2018 Share #22  Posted February 21, 2018 First, suggest a paper template to check whether dimples are indeed in the right place. Available online. See here https://lavidaleica.com/assets/articles/M9_Lens_Coder_V3.jpg  Second, use matt black paint to fill in the black pits. White is not necessary. Link to post Share on other sites More sharing options...
james.liam Posted February 21, 2018 Share #23  Posted February 21, 2018 First, suggest a paper template to check whether dimples are indeed in the right place. Available online. See here https://lavidaleica.com/assets/articles/M9_Lens_Coder_V3.jpg  Second, use matt black paint to fill in the black pits. White is not necessary.   Dead link. Link to post Share on other sites More sharing options...
rramesh Posted February 21, 2018 Share #24  Posted February 21, 2018 Dead link.  Try this. https://lavidaleica.com/assets/articles/M9_Lens_Coder_V3.jpg 1 Link to post Share on other sites More sharing options...
jdlaing Posted February 21, 2018 Share #25  Posted February 21, 2018 Would matte paint be a better option? That’s what I used. Link to post Share on other sites More sharing options...
bocaburger Posted February 22, 2018 Share #26  Posted February 22, 2018 Would matte paint be a better option? I used Testors model car/airplane flat black enamel. A tiny little bottle from the hobby shop is enough to do a slew of lenses. Link to post Share on other sites More sharing options...
robsonj Posted February 23, 2018 Share #27  Posted February 23, 2018 Advertisement (gone after registration) Must be my paint (flat black rustolium), that or the direction of the wind, relative humidity or sun flares . I downloaded the template, cut it out, checked that my mounts had the markings in the correct place - they're bang on. I mounted my newly acquired 6bit coded Elmarit-M 90mm to the 240, bang, recognizes the lens straight away, my attempts, not so much :-(. Link to post Share on other sites More sharing options...
jdlaing Posted February 23, 2018 Share #28  Posted February 23, 2018 Must be my paint (flat black rustolium), that or the direction of the wind, relative humidity or sun flares . I downloaded the template, cut it out, checked that my mounts had the markings in the correct place - they're bang on. I mounted my newly acquired 6bit coded Elmarit-M 90mm to the 240, bang, recognizes the lens straight away, my attempts, not so much :-(. Did you stir the Rust Oleum really well? To make flat paint a flattening paste is used and it sinks to the bottom of the can. Link to post Share on other sites More sharing options...
robsonj Posted February 23, 2018 Share #29 Â Posted February 23, 2018 I shook it very well. I'm gonna add more coats to ensure the coding pits are filled up with paint as I noticed the coding on the Elmarit-M are quite flat. I also tried using the template and a sharpie on the lens mount, also no dice. Link to post Share on other sites More sharing options...
jdlaing Posted February 23, 2018 Share #30 Â Posted February 23, 2018 I shook it very well. I'm gonna add more coats to ensure the coding pits are filled up with paint as I noticed the coding on the Elmarit-M are quite flat. I also tried using the template and a sharpie on the lens mount, also no dice. Use a stick to stir it too. That paste is like a sludge on the bottom. Link to post Share on other sites More sharing options...
Stonewall Brigade Posted February 23, 2018 Share #31 Â Posted February 23, 2018 You'd think by now, a company would have come out with a decal adhesive set for all Leica lenses, and anyone could just easy purchase and apply the correct decal with coding relevant to the lens Link to post Share on other sites More sharing options...
robsonj Posted February 23, 2018 Share #32 Â Posted February 23, 2018 Yep, I had the same thought, or pre coded flanges Link to post Share on other sites More sharing options...
Exodies Posted February 23, 2018 Share #33 Â Posted February 23, 2018 I hope the flanges fit tighter than would allow a sticker between Link to post Share on other sites More sharing options...
robsonj Posted February 23, 2018 Share #34 Â Posted February 23, 2018 (edited) A flange with a recess for a sticker is what I was thinking Edited February 23, 2018 by robsonj Link to post Share on other sites More sharing options...
