I believe that prior to the R-L Adapter came out, the only option was to stack adapters like you had suggested. I would think that the single R-L Adapter is the better solution,
but I would recommend reaching out to Dave Elwell at Leica in NJ for the best solution.
-Brad
So just to clarify, with a novoflex adapter I wouldn't be able to manually select an R lens profile by going through the menu?
As a cheaper alternative, has anybody here tried a 200mm Nikkon AF D f/4 for macro work on the SL?  How does it compare to the 100 apo R?
Cheaper alternative if you don't mind manual focus … and which is usually better for life size macro imaging
… but you'd also need the 1:1 FD extension tube … http://www.ffordes.com/product/17020210182481
…  the lens alone would be OK for 1:2 macro i.e. half life size.
Or this Leica R Macro Elmar 100/4 lens with bellows would be fine for 1:1 macro with an R to SL adapter
… most of James Lager's Leica book illustrations were photographed with this lens; stopped down to f8 it's a super lens but not many photographers realise what a gem optic it is.
Lighting and subject support and camera / lens support are just as important as the lens for close-up photography … and manual focus is preferred by many close-up enthusiasts.
Unlikely that an R lens profile (or any other 'profile') would be of much use (if any) for close-up imaging.
dunk
Edited by dkCambridgeshire
