HDTV format on digilux-2
daveleo
hi there
i think i have this correct, but would appreciate some verification or correction.
the D2 has an HDTV aspect ratio format option.
my question regards the resolution of a JPG image.
the resolution is established by the compression level set by the user, it is NOT effected by the selection of the HDTV aspect ratio. that is.... the "high definition" term doesnt mean better resolution.
correct?
the HDTV format is a simple masking action..... the image perspective is not effected by this selection (at least i cant see it having an effect). the image is panoramic only in the sense that it is wider than it is tall .... it is not extreme wide angle..... or are my eyes gone bad?
correct?
the D2 is my main camera on an upcoming trip, but i am bringing 2 film cameras as backup because i understand them a lot better than i understand digital.... so if you can clear this up, it would be appreciated.
regards
daveleo
Do you mean the Digilux 2 od the DLux 2? I think you mean the latter.
AFAIK, the HDTV mode simply refers to an aspect ratio so that you can display it on a screen, it has nothing to do with higher resolution as such. The image is cropped from the full frame image.
Davelo,
It is just a reduced resolution they decided to offer, 1920x1080 rather than the full 2560x1920. It gives you a 16x9 format. Better to learn where the 16x9 format fits within the full frame and crop after you get back. You'll have more info to play with. So to answer your question, yes it is a masking question, but is is also a lower res. shot. 'HD' is very miss leading in this respect.
thank you
i do mean the digilux-2 (not the dlux-2).
i was trippng over the "HDTV" terminology .... this is merely an aspect ratio change, not an improvement in image detail (which i was calling "resolution").
i understand now that it is simply a masking feature.
thanks
daveleo
