Has this happened to anyone else? So, yesterday, I'm shooting with my CL set on single capture and autofocus. I switched to manual focus using 50/f/2 Zeiss. Then, I switched back to AF using the 18-56 kit lens. No little green + showed up. Autofocus did not seem to reengage. So I saved my user info and reset the camera. Everything worked fine after that.
Pretty weird........
I’m not sure if this is related but whenever I change lenses (just one TL lens to another) the AF mode switches to Touch AF. Is anyone else experiencing this?
- Vikas
Edited by vikasmg
I have experienced the CL switching from field AF to touch AF when using the app. It seems there is something spooky going on with your manual to lens change situation as well. Sounds like it is repeatable from your experience. I haven’t seen it myself going from my 18-56 to my 55-135.
Was the camera still switched on when you did the lens change? Is it consistent whether the camera is on or off when you make the change?
Edited by Tobers
I have to test it out, but I always shut the camera off when I change lenses.
Good advice. I have no experience with TL lenses but the camera fails to recognize some coded M lenses if i don't do that.
the leica M adapter has some kind of quirk ["memory" perhaps?]...sometimes on the T i had to remove the adapter and put it back on in order to recognize the lens
