tabosko Posted October 7, 2017 Share #1 Posted October 7, 2017 Advertisement (gone after registration) Hello all, Wanted to know is the 35mm and 50mm crop a crop of the image (taken at 28mm then cropped) or a sensor crop (basically operating like a APS-C camera) ? Link to post Share on other sites More sharing options...
Advertisement Posted October 7, 2017 Posted October 7, 2017 Hi tabosko, Take a look here Q 35/50mm crop. I'm sure you'll find what you were looking for!
wda Posted October 7, 2017 Share #2 Posted October 7, 2017 The options are reversible in post processing. Just select image crop and the entire 28mm frame is still available. Quite a good compromise in my view. Link to post Share on other sites More sharing options...
HighlandK Posted October 7, 2017 Share #3 Posted October 7, 2017 I am not sure I follow the distinction you are making between a crop of the image and a sensor crop. If by a sensor crop you mean only part of the sensor is activated then the answer is no. The JPEG output is a cropped down version of the 28mm image but the RAW (DNG) output is still the complete full frame at 28mm. The cropped JPEG of course still has all the visual characteristics (e.g. perspective) of a 28mm lens. Link to post Share on other sites More sharing options...
SonomaBear Posted October 7, 2017 Share #4 Posted October 7, 2017 For portraits, I choose the 50mm perspective then can touch up the crop in post. There is insane detail in the RAW so I can even zoom in to an 85mm with acceptable detail (not like using 85/1.4 but ok for Facebook) Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
jmschuh Posted October 12, 2017 Share #5 Posted October 12, 2017 Hello all, Wanted to know is the 35mm and 50mm crop a crop of the image (taken at 28mm then cropped) or a sensor crop (basically operating like a APS-C camera) ? There would be no difference in the image quality... but the Q takes the full image and crops the 35mm from this full image. The RAW file is always a 28mm (ca. 26mm in reality) image, only JPG files are cropped. Link to post Share on other sites More sharing options...
LucisPictor Posted October 12, 2017 Share #6 Posted October 12, 2017 But isn't it true that the Q only measures the cropped frame? Thus metering should be more accurate than with a later crop. Link to post Share on other sites More sharing options...
jmschuh Posted October 12, 2017 Share #7 Posted October 12, 2017 Advertisement (gone after registration) But isn't it true that the Q only measures the cropped frame? Thus metering should be more accurate than with a later crop. Yes, metering only affects the part in the cropped frame. Link to post Share on other sites More sharing options...
SonomaBear Posted October 14, 2017 Share #8 Posted October 14, 2017 But isn't it true that the Q only measures the cropped frame? Thus metering should be more accurate than with a later crop. Not sure since the entire frame seems to always be exposed properly even when the jpeg is cropped. I often shoot with DNG & JPEG so that I can download a JPEG onto my iPhone to transmit unedited images, then have the RAW for post processing. Link to post Share on other sites More sharing options...
