PocketWizard or similar radio trigger for 1/1000 sec.
ynp
We need to shoot some three dimensional stuff outside with multiple strobes and modifiers.
We want to kill the ambient light and frieze the flowers in the foreground of the object.
I will be using my S2 with its lowest 160 ISO. I will be able to borrow the S30 CS and S45 CS with its 1/1000 sync and use my Hasselblad HC lenses with very reliable 1/500 or a bit shorter.
I will be using three power packs, two Broncolor Grafit and one Briese Cube. All my power packs (generators) lack any RFS or similar radio receivers, they are old. The tests showed that I can successfully sync the Leica S CS lens shutter if I hardwire the camera and generator with the cable. The optical triggering on the far away generators is too slow and unreliable. My Chinese triggers work only on 1/250 and I cannot use them for this job.
What do you think I shall buy or rent to get the synchronization by radio? Any PocketWizards or anything else? What is the best solution?
Thank you!
Yevgeny
P. S. I don't want to mess with the composite this time and I want to do everything in the camera.
sorry when I'm to late but I used my S2 successfully for some years with pocked-wizzards and Nikon - SB 900 (five of them). Nevertheless this is a bit cumbersome and I woulnd't do it again today especially if I had to buy them new. On the other hand, for some specials needs this works very well
  • 3 weeks later...
