Einst_Stein Posted May 29, 2017 Share #1 Posted May 29, 2017 Advertisement (gone after registration) As an old gereration camera, Digilux has much lower usable ISO. But the absolute ISO is not necessary a meaningful matrix. Theoretically you can amplify the signal with any amplification gain, but it does nitnecessary hold the details. ... like you can use a super amplifier to amplify the music to let the whole town to hear it, but t does not necessary sound beautifully. Dynamic rangeis is also not just means a wide data size Analog/Digital converter. Using 16-bit Color depth sampling ADC does not necessary mean the extra few bits can really capture more information. It is like using the best tape recorder to record a music in a noisy and bad music hall. Not matter how god is the sensor ADC, an imgage from a bad lens is still a bad image, it is garbage in garbage out. Said that, how is Digilux 2 effectively, appreaciatable dynamic range?, say compare to other Panasonic breed Dlux, or Fujifilm X30? And how was it tested? Link to post Share on other sites More sharing options...
Advertisement Posted May 29, 2017 Posted May 29, 2017 Hi Einst_Stein, Take a look here Digilux 2 dynamic range, And how to test. I'm sure you'll find what you were looking for!
lct Posted May 29, 2017 Share #2 Posted May 29, 2017 I'm no techie at all but amplifying a noisy signal can hardly remove its noise IMHO. To compare apples and oranges, my Pany Lx100 (DL 109's clone) is cleaner at 3200 iso than my Digilux 1 was at 200 iso. FWIW. Link to post Share on other sites More sharing options...
jaapv Posted May 29, 2017 Share #3 Posted May 29, 2017 https://luminous-landscape.com/digilux-2-lc1-dxo-test-report/ Link to post Share on other sites More sharing options...
