Big John Posted May 16, 2017 Share #1 Posted May 16, 2017 Advertisement (gone after registration) Hi all, Just a quick question pls. Am a bit confused re build and weights of the 35mm FLE in black v silver. Are they both anodised aluminium now so same weight? Or is the silver made of brass and heavier? I know this case with the Cron. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted May 16, 2017 Posted May 16, 2017 Hi Big John, Take a look here 35mm 1.4 summilux asph FLE quick question. I'm sure you'll find what you were looking for!
Big John Posted May 17, 2017 Author Share #2 Posted May 17, 2017 Found the answer - lots of confusion out there on the internet (people comparing older models where chrome lenses were heavier). Answer is that latest models are same weight. The new Leica Summilux-M 35mm f/1.4 ASPH in Silver Anodized Finish is optically and mechanically identical to the black chrome version, and weighs the same thanks to its aluminum construction. 35 mm lenses are the most popular in the M-System. Their mixture of moderate wide angle characteristics paired with natural dimensions make this focal length extremely versatile. Often, it is the first choice on a new M camera, and therefore many famous pictures have been taken with a 35 mm lens. Link to post Share on other sites More sharing options...
lct Posted May 17, 2017 Share #3 Posted May 17, 2017 Thank you for sharing. Would you have a link to that info? Just curious. Link to post Share on other sites More sharing options...
TheGodParticle/Hari Posted May 17, 2017 Share #4 Posted May 17, 2017 I have the chrom and black FLE versions and I can confirm they are of the same weight. The Chrom lens is anodized as noted and not made of brass. I have the preFLE chrom version as well and it is noticeably heavier as it is indeed made of brass and is smoother to operate and the aperture mechanism is a lot more solid. Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
